Big cubic inches or blower for 650-700 hp? Carbed or fuel injected?
Not terribly aggressive, lift is just shy of .700 IIRC. To be honest I think the rockers failed because of a misfiring issue I had earlier this year. The distributor cap was trashed and it was miring multiple cylinders. I guess I should have mentioned that in my initial post.
Not quite the 650hp as asked for but my 454 with good internals, hyd roller cam, 177 blower and stainless marine manifolds make 610 hp and starts and runs like a fuel injected motor. I would say not a high dollar if you already have the parts like I did but with better heads and a 502 you could easily hit the 700 hp and be very reliable.
Big cubic inch tall deck , 87 octane , iron eagle 345 's spend money on valve train stability i.e. shaft rockers , high end solid rollers . Definitely carbed maybe a short tunnel ram with twin 660's , big tube etops
keep rpm to under 6k , set lash once a year , enjoy boating
I currently run a N/A 548 in my 30ft boat and it is really easy to drive but I have no space for pulleys to install a blower. I run at high altitude so a blower would actually help me out a lot but a boat at sea level will have plenty of air. I come from drag racing and was expecting to see more of the big cubic inch 632's and even larger N/A motors in these big boats. Pretty easy to get 900-1000 HP these days with a single carb on pump gas with a 632.
For the OP, 700hp is easy and relatively cheap on pump gas NA. Above 700, blower.
While a lot of boat motors are built like drag racing motors, you can't get too crazy with boat motors because they take much more abuse than a drag motor. You don't see a lot of boat motors over 565ci because above that, the wrist pins are way up into the rings and overall the pistons are weaker. Also a more aggressive cam = water reversion in a boat. Obviously exceptions to this using big aftermarket blocks with 5" bore spacing for more cubic inches, dry exhaust for water reversion etc $$$. Overall, boat motors are built like tanks, and tuned very conservatively. My motor is capable of 1000+ hp in a car, but tuned for 825 in the boat.
On the 27 Advantages, they have 2 molds, one has a notch in the bulkhead in front of the motor to accommodate a blower pulley just for that reason. They probably didn't worry about that with your boat because nobody was using blower motors in those boats then lol!
