So, it sounds to me like it would be just as good as muffs to go ahead and install a "T" before the seawater pump. That way, when the fresh water from the hose is turned on (at first), it will run out thru the drive, thereby "flushing the drive". Then, turn on motor to have the rest flushed out. But, when you turn off the motor and the hose is still running, you'll get a quick second flush of the drive. What material would be the most effective for the T to be constructed? Anyone know what diameter hose I'll have to cut into so I know what size "T" to get?
Merc. sells a kit that works really well. I just had them put on my early model 525's when they were out for freshening last winter. I am sure they will work for your 502's. Comes with a quick connect for the garden hose and a bracket that mounts to the water separator housing. I believe they were standard on the later model 525's. Makes flushing pretty easy. I was in the same situation as you with a lift and no access to the lower unit water pick-ups.
I believe the inlet hose is 1 1/4", so you would need a 1 1/4 tee with a 5/8" or 3/4" take off. I forget what I had, been awhile. I actually made my tee's from SS. I think you can buy just the tee from CP
Added, you can use this tee and simply install a hose barb to connect your flush hose too. Ive seen some use the heavy gray PVC tees from Menards. Pump housing is plastic, so this shouldnt be any different?? http://www.cpperformance.com/p-977-1...se-12-npt.aspx |
My be a dumb ? But can you winterixe through the flush port? |
Originally Posted by therealmccoy
(Post 4645094)
Originally Posted by DiamondPerformance
(Post 4597906)
We sell these - DELUXE FLUSHING KIT WITH DECK FILL :: Engine Flushing Kits :: Diamond Performance Parts
Originally Posted by alindquist
(Post 4645142)
Would this work on a Volvo D6 diesel? I'm about to move my boat to a lift and need to do something like this...
Awesome thanks for the quick response! |
Originally Posted by US1 Fountain
(Post 4597926)
When done flushing, remove the hose and install the cap on the garden hose fitting. You must keep that capped tightly during normal operation. If the cap is loose, the seawater pump will suck air thru it and not water thru the drive.If you feel uneasy about the cap coming loose, you can install a valve before the fitting as a added insurance.
I saw the T you recommended. Where do you get a garden hose fitting with a plug and/or an inline valve to close off the garden hose leg when not in use? Thanks, Tom |
Originally Posted by F14A water jet
(Post 4735176)
I like this method.
| All times are GMT -5. The time now is 12:27 AM. |
