Fountain 29 2011 700sci
Old 03-07-2018 | 09:59 PM
Default Fountain 29 2011 700sci
i own the last fountain made from fountain factory in 2011 since 4 years right now it came originaly with 600sci and ITS BOX xr drive with shorty ssm lower maximum 5 blade 28 pitch.. i chamge programationbox computer and wheel upgrade stade 700sci.. run 83-5 i want to find way to reach 90 ! X ratio too high? Swap xr lower? Switch to 4 blade biggest pitch ?? Help me please!!
sunsass is offline
Old 03-07-2018 | 10:45 PM
I would think you could be running faster than that. I have a 05 29 575 and run 81-82. Running stock XR with 30p Bravo 1... the Maximus 28 on the boat runs about 77-78. I think the 5 blade is better everywhere except top end. So if you want too end- I’d say put a 30-32p Bravo 1 on it.
precisiondetails is offline
Old 03-10-2018 | 02:43 PM
Thanks !! I will try xr long lower and 4 blade props .. think im gonna be able tonget good on plane with all the power i got..
sunsass is offline
Old 03-10-2018 | 07:15 PM
Too Stroked's Avatar
Be careful getting that one on plane with lots of power. 29 Fountains are pretty tough on drives. Baby it and use lots of tab to get on plane.
Too Stroked is offline
Old 03-11-2018 | 03:53 AM
glassdave's Avatar
Neno the mind boggler
what gear ratio in drive? i am thinking 1:36 gear and 28 or 30 B1 maybe?
08 OPA High Points Champion
glassdave is offline
Old 03-11-2018 | 10:47 AM
Well mine is a 1:50
Old 04-18-2019 | 01:07 AM
Default Fountain 29 2011 600sci upgrade 700 programation looking for new max5 prop
I wont advice for appropriate prop on my 29 fever run 78 presently with maximus 5 blade and ssm bottom with ITS box extention . I know x dimention is high but dont know if its 19 or less ... expect to reach 85 with mupgrade 600sci computor bx and wheel chamge 2 years ago. Love the boat but enable to set prps drive for good launching and top end . Lot of choice about pitch size of the news max 5 short tube 15" (inboard recommandation size) about 28 to 34 . Anywone can help me about appropriate sise of props or spacer
sunsass is offline
Old 04-18-2019 | 10:02 AM
I'd call BBlades
ALL_IN! is offline
Old 04-18-2019 | 03:04 PM
See how fast does a single 525 29' Fountain runs if in the 80's copy set up? A Bigger prop with your power that may be the trick for top speed you want ??
Nothing personel 353 is offline
Old 04-18-2019 | 06:49 PM
What exact did you change for 700 update?only ecu programm and smaller pulley??
To make it a real 700sci it needs also a cam change when use oeginal merc 700 ecu!
Michael
Brembofreak is offline
