‘Game Changer’ Skater 438 Hits 180 MPH On Mercury Racing 1350 Power
For record, my friend, this sentence in the story came directly from Peter Hledin: "The Skater 438 is a scaled up—by 10 percent—version of the company’s vaunted 388."
But, yes, the 43-footer’s bottom is dramatically different than that of the 38-footer, again according to company principal Mr. Hledin. So, while the 388 and 438 are, in fact, rather different (and the bottom designs are completely different) the 438 does, in fact, have a quite a bit in common 388. That information came directly from Mr. Hledin and, trust me, if I got it wrong I'd have heard about it. (He does not pull punches.)
But no one has to take my word for it. Anyone can call him or Tony Cutsuries and get the same (correct) information.
Ok well that is clearly a more in depth explanation. I was just going off what I’ve read and have been told. Talking to Pete one day he told me there was more difference between the 68 & 88 then that. But I do believe you. I’m just stating what I’ve learned. Either way that 438 is unreal. Those speeds are crazy good. Efficiency is through the roof as well.
So with that said-
Dale, do you see Skater going back and tweaking the likes of the 68 & 88 to bring them some what up to par with this “next generation Skater”?
Hey Chad, there may well be a few more slight differences between the 368 and 388, but they are so similar that you can't tell which is which from standing behind the hulls when they are side by side at the factory. The 438 is a completely new boat, and looks completely different when side by side with a 388 or 368. And I'm talking about when the boats are just hulls, fresh out of the molds, before they even are cut and readied for flat decking. You can see that the 438 is a different hull from the 388/368, different from a 40 or 46 also, even with nothing else to give it away. As to tweaking existing models to bring this latest technology across the line, I will leave that answer to Pete and Tony. Pete and I had lengthy discussions about this while my 30 was being converted, but I don't feel that's information that I should be sharing.
What do you think of the Ceramic Coating I did to Robs boat? I could do yours when you bring it home if you want bud.
Correspondent
Correspondent
Lol, I don't doubt at all that he told you that Matt. What you couldn't see through the phone line was the smile on his face as he was telling you that. It's not my place to give every last detail of Skater's newest boat, but you know that I do everything I can as a friend of Pete's to support their lineup. I just want guys to know that it truly is an all new boat, and it is the first Skater with a completely different hull design since the 40 was first built after the 32A. Trust me, once you see the bottom of the 438, you will see how different it is (I have pictures, but it's not my place to post them). If I won the Lottery tomorrow, it would be the boat I ordered - that's for sure!
https://speedonthewater.com/new-boat...ing-1350-power
https://speedonthewater.com/new-boat...-438-catamaran (Tony Cutsuries: “It’s a 388—all pumped up,” he added. “It’s 10 percent bigger all the way around.”
https://speedonthewater.com/new-boat...78-438-and-318
Yes, the 438 is a "new model" and, yes, no two Skaters are absolutely identical. But according to Mr. Hledn and his national sales manager, it is based off the 388 (as stated in the article) and its general specifications are essentially scaled up from that model to be 10 percent larger/longer. And that is what was accurately stated in the article. I stand by it.
All I can do with sources who have earned my trust—and no one has earned more of it than Mr. Hledin—is trust them to be truthful. Mr. Hledin, who I first interviewed at his plant in the late 1990s and have interviewed more times since than I care remember, is among the most brutally honest people I know. I take him at his word. (Interpreting smiles, particularly hypothetical ones, isn't part of what I do ) Below is our reasonably thorough coverage from June 18, 2015, through April 4, 2018, of this build.
abones (04-06-2018), davidmercury (04-07-2018), Double Rigged (04-06-2018), Jimboat (07-02-2021), ntesdall (04-06-2018), precisiondetails (04-06-2018), pstorti (04-06-2018)
[QUOTE=Skater30;4620174] Once again, Skater is leading the way in catamaran hull technology.........
Let’s not get too carried away. George Linder, Steve Koss and the UIM Formula 1 class have been utilising various iterations of this geometry for decades..
ND1
ND1
[QUOTE=nautdesign1;4620238]wow, that was a sneaky way to get linders name into a conversation. The Chris cat had a flat pad. A design more relevant to the west coast boats. koss made a narrow sponson and wide tunnel. Both as far apart from the Skater as one could be
[QUOTE=Boatlesss;4620297]
1) The concept is the same as the Linder hulls but the low deadrise planes are not longitudinally continuous which results in diverging angles of incidence. That’s why I used the term ‘iteration of the geometry’;
2) For a much closer example look at the F1 boats:
F1 Powerboat World Championship Guido Cappellini Picture to Pin on Pinterest - PinsDaddy
3) Also have a look at the image in post #116 in the following thread:
Technical Questions For Steve 1
Anything look familiar?
ND1
ND1
Linder didn’t invent the cats, and Linder wasn’t the first nor only one to use a padded bottom. That’s a derivative of the delta bottom which was used on many boats.
Are you inferring that the chris cat was the mother for all the modern cats?
How do you derive that question from my previous posts? It appears you have a thing for Mr. Linder but I reference him ONLY as yet another example of a designer that utilises variable lateral dihedral (or deadrise) in sponson design. Interestingly the span of the very low deadrise sections on the ChrisCat is too narrow to provide a great deal of benefit at the speeds he designed it for –particularly given the boat’s considerable mass. The other problem is the effective low deadrise of the ChrisCat’s overall sponson section reduced dampening and this contributed to that annoying porpoise –but that’s another conversation.
Back on topic –As I mentioned previously the other two are much better examples of the point I am making. I included a couple of visual links in the previous post so why not have an objective look?
ND1
