Would help to have more info? HP of engines and RPM they are turning current props,as F2 Speedy mentioned. Prop shaft centerline to bottom of boat? Drive type? Gear ratio? Which 28? Pleasure set up, cabin gutted, etc.?
Originally Posted by gerrypantera
(Post 4634666)
I had bravo 32s on and the slip was 20% the maximus seems to be the better choice for lowering the slip i beginning to think stick with the bravos and drop drives down an inch ? Engines are twin 350s
Just my $0.02 |
Originally Posted by Rookie
(Post 4634761)
I would not worry about slip. I believe too many people hunt for great slip numbers with props; blades, labbing, geometry etc... and truly miss out on a good handling boat with proper ride in all conditions. Let's say you have props that are at 29" @ 24% slip 72mph, 44mph cruise, but you love all aspects about them. Carry bow, right amount of stern lift, great in rough water, plane good and you have nice speed. You then get a set of 26" @ 15.5% slip 71mph, 46mph cruise with an extra blade and you lose some driving ability is it worth having good slip numbers??? This had been my issue chasing slip #'s. I have 5 different style of props laying around collecting dust now. My Panther would porpoise with Hydromotives.
Just my $0.02 |
With 350s& 32" props how the hell did you ever get on plane.I would think 22"s or maybe 24"s would be your best bet. |
There 350 hp diesels if im right |
Originally Posted by bor
(Post 4635460)
Where the OP? Darr?
Gigo
Originally Posted by Indy
(Post 4635466)
Diesels? In a 28? How does it float?
so it float just as whit Twin big block If i m right he have 1:35 ratio drives |
did not read any of the posts - only the heading.
check the bottom of the hull for a rocker --- possible ? Too much stern weight ? any gained weight here ? water intrusion ? Balanced hull ? Prop a better one to carry the bow trim tabs ? |
| All times are GMT -5. The time now is 09:33 PM. |
