Run engine on hose w/o impellor
On a 100 foot hose, 3/4 i.d., and the earmuffs modified with dual 5/8 i.d. hose, 5/8 i.d. fittings and the Y pipe gutted out.
I get 5 gallons a minute, and 5 gallons a minute w/o the earmuffs.
Question would be is 5 gallons enough for idle to flush engine w/o hurting the seapump?
Only mod left would be to cut the hose down to 30 feet and run the boat next to the house rather than in its parking place.
I dont see shortening the hose doing much...X amount of water goes in to the hose, X amount has to come out the other side, whether its 3 feet or 300....
Not 100 % sure but doesn't the power steering shaft have an Allen head recess in it ? If so you can just loosen the belt and and spin it without taking the pulley off. Makes that part a little simpler at least.
Straight bottoms and flat decks
