Headers on a 496 HO
Old 11-06-2018 | 03:21 AM
Thank you Griff now I know what kind of headers I might end up buying
Monaco20 is offline
Old 11-06-2018 | 06:39 AM
Personally I’d skip adding headers on a 496...the cons (leaking welds) far outweighs the benefits (looks and sound). Just my 0.02.
1MOSES1 is offline
Old 11-06-2018 | 06:53 AM
Dana's are somewhat reliable and priced fair.
Keith Atlanta is offline
Old 11-06-2018 | 07:04 AM
The reason I consider this option are because I need to change next season, engine are a 2009 model not changed before.
The CMI Split Top Headers are almost not used even though they have some years, and I can get them for 450 USD
I do not think they have any leaks but I are going to pressure test them anyway..
If they are ok, its a good deal ..
Keith Atlanta what kind of engines du you have in your Baja ??
Monaco20 is offline
Old 11-06-2018 | 11:29 AM
BUP
not sure as I do not recall ---- Maybe when CMI first came out with marine headers - did they have external welds ? ?? Possible a knock off header ??. And Yes CMI did have headers like the ones in the pics but I do not recall being external welded.
BUP is offline
Old 11-06-2018 | 12:07 PM
The visible external welds are normal on satin finish CMI's from what I have owned and seen.
I think CMI smooths them out on the polished versions so they become virtually invisible.
Griff is offline
Old 11-06-2018 | 12:22 PM
I sent the pictures to Custom Marine and they confirmed that they are CMI top split headers sold in the 90s replaced by the CMI Sport Tubes
Price at the time they where sold aprox 3.500 usd
Monaco20 is offline
Old 11-06-2018 | 12:27 PM
Personally, if I had it all to do over again I’d buy a good set of manifolds instead of the old CMI headers that I got. They were fresh water units and pressure checked, but a few months later my engine wouldn’t turn over because the #5 cylinder was full of water. Unless you’re going for a big power build with all brand new parts I’d stick with some good manifolds. That’s my $0.02. But best of luck however you go!
Baja Rooster is offline
Old 11-06-2018 | 01:16 PM
496's converted to Raylar 600 packages and Dana manifolds.
Old 11-06-2018 | 01:30 PM
Nice package, I have been thinking about install a Procharger on my 496 HO, with a mild boost 3,5 psi should give me aprox 550 HP
Monaco20 is offline
