Closed cooling BBC
Old 12-03-2018 | 05:44 AM
That is a half system , I am looking for a full system to include exhaust manifolds.
open87 is offline
Old 12-03-2018 | 06:35 AM
Dean Ferry's Avatar
Veteran: Air Force
Originally Posted by scippy
That's a clean looking engine how many hours on it?...........salt water use only?........a full closed cooling system would extend the inside life by double!
S,
Thanks, I'm pretty anal about my equipment... Hours are ~290, 90% saltwater use....
Dean
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 12-03-2018 | 08:52 AM
I used monitor and am very happy with the product. Stock 502 mpi mag almost all salt water usage. No overheating issues
smokediver is offline
Old 12-03-2018 | 08:57 AM
Originally Posted by Dean Ferry
S,
Dean
if you do go closed cooling it would be smart to run only distilled water in your cooling system about the first 5 times out and drain and refill ..The distilled water will help pull the salt out that has leached into the cooling passages. If you just add a coolant you risk turning it into a gel...
Old 12-03-2018 | 11:45 AM
Plenty systems around for Factory power , what this hunt is about is finding a FWC system big enough for more cubic inch/ horsepower and also cooling aftermarket exhaust. That system a few post back is awesome but isn’t a full system.
open87 is offline
Old 12-03-2018 | 07:40 PM
scippy's Avatar
More likely it would seem to be for larger cu. in. engines a custom fabrication of sorts would be required for a FWC systems & exhaust........I can see this getting very expensive.
scippy is offline
Old 12-03-2018 | 10:15 PM
Park35, what is the size of that exchanger 5x30?
open87 is offline
Old 12-04-2018 | 04:22 AM
5by 27...hi flow
park35 is offline
Old 12-04-2018 | 11:39 AM
scippy's Avatar
Open 72.......So we both have tall decks (mine BBC 572 cu. in.) wondering what size heat exchanger would be adequate to cool a full system.
scippy is offline
Old 12-04-2018 | 03:19 PM
Dean Ferry's Avatar
Veteran: Air Force
Same here, and I'm either going to put KE manifolds or IMCO Powerflow Plus on my 572....
