First Quad-Outboard TrimSync Application In Action On Nor-Tech 390 >
Old 03-03-2019 | 05:08 PM
Originally Posted by speicher lane
GF? = Got Freedom?
Yes, GF? is Got Freedom?. That is the name of my 42' Fountain
Got Freedom? is offline
Old 09-12-2021 | 02:29 AM
Default Wiring TrimSync
If you have a twin engine outboard setup with a BOTH switch and trim diodes, do you connect TrimSync to your existing BOTH trim switch, or do you add an extra switch?
(the instructions only describe the trim pump side of things)
I suppose you would still need to add a button for each pre-set.
Any experience of the TrimSync with Bob’s jack plates? The pumps are regular trim pumps, so it comes down to if the senders work.
Markus is offline
Old 09-14-2021 | 11:43 AM
You would use the existing trim (both/all) and TrimSync is compatible with Bob's jackplates.
GF?
Old 10-26-2021 | 12:16 PM
Awesome.
Have added to shopping list.
Markus is offline
