Looking for an-npt fitting /adapter >
Old 04-14-2019 | 07:32 AM
aeroquip and fragola have what you want , or send it to mark
dunnitagain is offline
Old 04-14-2019 | 08:42 AM
Think I found it....
Fragola Performance Systems Flare Caps 492928-BL
phragle is offline
Old 04-14-2019 | 09:56 AM
SB
Yup, good find.
SB is offline
Old 04-14-2019 | 10:30 AM
Mbam's Avatar
Offshoreonly Advertiser
I'm off the hook
Mbam is offline
Old 04-14-2019 | 01:17 PM
Originally Posted by Mbam
I'm off the hook
but we thank you for your offer !!
phragle is offline
Old 04-14-2019 | 07:07 PM
Well shoot! Guess I better find senders for water pressure and boost. I have poly lines running to the helm for both these gauges.
jamontes is offline
Old 04-14-2019 | 07:15 PM
Get a local hose company make you some nice high pressure lines.
underpsi68 is offline
Old 04-14-2019 | 07:51 PM
Rookie's Avatar
Totally different situation than running fuel to your helm. I was given 2 mechanical fuel gauges 10 yrs, just never had the balls to run fuel to my helm after having a poly water pressure line leak. They are still on the shelf.
Rookie is offline
Old 04-14-2019 | 08:37 PM
SB
Not how you make hydrogen fuel. yeh, joking,
SB is offline
Old 04-15-2019 | 12:11 PM
RSCHAP1's Avatar
Run an isolator for a mechanical gage so fuel isn't plumbed under the dash/helm.
Leaking boost pressure or water isn't as dangerous or flamable as fuel is.
https://www.summitracing.com/parts/atm-5282/overview/
https://www.autometer.com/high-press...r-300-psi.html
Instructions
This isolator is installed in the pressure line between the carb or fuel pump (where you normally pick up fuel pressure) and the fuel pressure gauge. It has a diaphragm that prevents fuel from reaching the gauge (inside the driver's compartment). The driver's side of the isolator and the line to the gauge are filled with a fluid that transfers the pressure to the gauge.
RSCHAP1 is offline
