Sealing exhaust tips
OK, now that I have my exhaust pipe sealed on the outside, I hope, I find that there is a larger hole in the transom than the pipe diameter which leaves a gap as seen from the inside of the transom engine compartment. Should I be safe and inject 4200 into that space so it seals around the pipe on the inside of the transom and slide the rubber tube on the exhaust pipe up against the inside transom or just leave And alone. Thanks guys for your dedication and your help for us need to know people
Keep in mind that if an exhaust coupler leaks, water can run down the bottom of the exh pipe. You don't want to leave a space where that water can puddle where the pipe enters transom. I would either seal it or cut a notch at the bottom of the holes so any water that does appear there can drain to bilge and not puddle in the gap. Obviously, if there any exposed wood, that needs to be sealed.
If you decide to seal it up with sealant on the inside. I'd use RTV instead of 4200 (I'm assuming you used 4200 on the outside). Too much 4200 and those tips will be a bear to remove in the future.
People use 4200 and 5200 like it's the only stuff that's ever been invented and years later them , or some poor other sucka , has a nightmare on their hands.
