Need tips on floor dollys
Old 04-28-2020 | 12:24 PM
You might consider these AeroCasters made by my company.
mobuzz is offline
Old 04-28-2020 | 01:07 PM
resurrected's Avatar
Way cool!
Like a hovercraft?
resurrected is offline
Old 04-28-2020 | 02:46 PM
Had things like those that we moved Phalanx mounts around during assembly/repair
4 flat plates with a bunch of air holes drilled in the bottom
AllDodge is offline
Old 04-28-2020 | 04:12 PM
jeff32's Avatar
https://www.youtube.com/watch?v=UvOzrTRDxBI&t=11s
wow! very impressive!!!
jeff32 is offline
Old 04-29-2020 | 01:43 PM
If you turn the casters with a crescent wrench it will go wherever you pointed them.
Alwhite00 is offline
Old 04-29-2020 | 05:43 PM
jeff32's Avatar
will try that! Hammer was not efficient but did not hammered enough to damage the caster...
thanks!
jeff32 is offline
Old 04-29-2020 | 07:13 PM
The minimum size wheel I would use is 8". You can get casters that you can add locks to stop the swivel, I always add the locks to at least two casters on one side so I can lock them and be able to push and steer easily.
google 4-Position Swivel Lock I can't post pics yet
941 is offline
