Holley sniper efi
Old 09-22-2020 | 10:34 AM
  #51
Originally Posted by Baja Rooster
PM’s and email is where conversations go to die for me. My wife can confirm this, lol.
I don’t have any pics but the install is very straight forward and the directions are pretty clear. Loads of info on the holley boards as well.
I went with the Weldon 600A pump as they can lift as well as push.
I was lucky to already have a bung in the fuel tank for the return line. I believe I ran 5/8” fuel lines everywhere.
The DUI has been a great ignition for me. The previous owner just used the OEM 16g wire to power it. When I wired it properly it picked up 500 rpm just like that. I set the base at 18° and 32° all in.
It’s on a fresh 509 that *might* be close to 600hp in dyno trim. 272 Baja Islander.
I keep going back to this. You picked up 500 RPM by changing from the Purple wire in the harness to 12g from the starter basically?
TxHawk is offline
Old 09-22-2020 | 11:17 AM
  #52
Correct. I did make a jetting change as well but not that drastic.
Baja Rooster is offline
Old 09-23-2020 | 03:44 PM
  #53
You have me convinced. I didn't notice the 12 gauge requirement when I put in my DUI.
I just put 12 gauge through a relay today.
Interestingly the tech guy at performance distributors, the source for DUI, thinks the units only draw 3 amps.
Also he thought a fuse was uneeded. Sorry, I fuse things.
A 12 gauge wire can carry up to 20 amps. Electrical wisdom says protect the wires. So I installed a 7.5 amp fuse between the starter link and the relay.
I couldn't buy a relay with 12 gauge leads locally so I swapped the power leads over from 14 to 12 gauge. The notes on the relay box claim it has 30 amps capacity. Hmmm.
I'll carry some fuses I suppose.
It's supposed to be nice tomorrow so I'm planning to go for a ride. I'll see if I get any more rpms.
But I am in the middle of jetting and power valve tweaking too.
I'll have to stay way out in the middle, the lake is down 2 feet from drought.
NHGuy is offline
Old 09-25-2020 | 05:12 PM
  #54
What unit did you use? Also wondering can you get bigger screens or interface with a NEMA 2000 unit? I assume, (maybe should look myself) that Holley is running on a CAN BUSS, would be cool if someone made the conversion to NEMA standard messages.
Kid Turbo made a bunch up for some of us using Holley EFI so we could use a MFD for monitoring. Look him up -- he might have some left out of his last batch...
delsol is offline
Old 09-25-2020 | 05:15 PM
  #55
My bilge is a filthy mess and I haven’t tidied up the rigging yet, but you can see the general layout here with the return line doubling back with the feed line. In the bottom right you can see the filter head mounted as high as possible to help feed some head to the pump to help keep it primed. My return line goes back to the tank. You can plumb it back into filter head but that does heat up the fuel a good deal.
Does the Weldon pump not want to be lower in the bilge? When I spoke to those guys they wanted the pump below the fuel tank as they said the pump was not designed to pull and would inhibit the fuel supply...
delsol is offline
Old 09-25-2020 | 06:31 PM
  #56
Electric pumps should be as low as possible, but this was the best option I had for now and Weldon is the one pump that advertises that it can pull as well as push. Young and Harris both confirmed this (off the record of course).
You’ll also notice that I mounted the fuel filter as high as possible so that it always has a fresh head of fuel to prime with. It’s not perfect but has worked so far.
Old 11-25-2020 | 06:49 PM
  #57
jeff32's Avatar
Originally Posted by 12meter
I was thinking about starting a build thread with my 12 meter. Totally gutted at moment. Transom totally rebuilt. Motors built. Have brand new interior to install. Doing new paint.
you should indeed !
when are you posting up this new build tread ???
jeff32 is offline
Old 11-26-2020 | 07:22 AM
  #58
Not trying to highjack but I am going through kind of the same thing now. Getting ready to rebuild my 575's and change over to a better fuel injection system. My two choices are the replacement plate style, like Youngs performance, or can I go with Snipers?
dave krehbiel is offline
Old 11-26-2020 | 10:11 AM
  #59
Lightbulb
Dave , you could save a few bucks and just go cheap carb from last decade off ebay. Might spend a year and never get it right but carbs are more reliable so it would be worth it .
ICDEDPPL is offline
Old 11-26-2020 | 01:48 PM
  #60
Well, I like the sound of saving money just fine, but the never getting it right part doesn't sound fun at all. lol. I am looking at a couple of builders at the lake now and am upgrading from the flat tappets to a roller cam and want them dyno tuned and trouble free when I get them back in. I am going to be retired and too old to want to mess with them much any more. This boat has been a long project for me and am finishing the interior as well this winter, I just want to go boating this year!!!
