Hydraulic hatch issue
Should be a momentary switch. Jump the solenoid on the pump. The ram is a TRS ram cig used to actuate. Green is down, blue is up. Put 12volts to it. This will determine if its pump or not. Then you can determine if its a fuse, a connection, or bad solenoid. But you should hear a clicking noise. Good luck
You should have this switch for a hatch https://www.cpperformance.com/p-1310...ngle-pole.aspx
It may Look like that switch, but there is a difference between momentary and toggle switches. From your post it sounds like you have a toggle switch, when the hatch should have a momentary switch (where as soon as you take your finger off it stops moving).
Right, that doesn't happed with my switch for the hatch...obvious reason why it stayed on after it was clicked in down position...thanks for that!....will change them out as soon as I diagnose what's the problem here.
