Suggestions needed for painting bravo drive >
Old 04-11-2021 | 05:02 PM
Default Suggestions needed for painting bravo drive
I dock mine in freshwater and noticed drive area where SS prop and carrier area on lower it's starting to flake off. What options to redo the lower and products to use. I currently have merc primer and black rattle cans
thanks
PA.WOODCHUCK is offline
Old 04-11-2021 | 05:21 PM
thanks
Sand area, wipe with alcohol, zinc chromate, and then phantom black paint.
1MOSES1 is offline
Old 04-11-2021 | 06:58 PM
Thanks for the advice
That said is the Mercury primer zinc chromate?
Old 04-11-2021 | 07:05 PM
Install Magnesium anodes on your boat and outdrive for fresh water use. Zinc is used for salt water.
Interceptor is offline
Old 04-12-2021 | 01:45 PM
I thought Aluminum for fresh water?
ThisIsLivin is offline
Old 04-12-2021 | 02:11 PM
Yep, 100% ^^^ right there is the formula.
That primer makes a big difference and the Phantom Black is damn good paint for a rattle can.
Keith Atlanta is offline
Old 04-12-2021 | 02:47 PM
Either, although this chart I have saved suggest Mg primary, Al second.
cheech is offline
Old 04-12-2021 | 03:04 PM
no idea what primer you have...the zinc chromate we use typically comes in a green can with green top. It’s $15-20 per rattle can.
1MOSES1 is offline
Old 04-12-2021 | 03:11 PM
I have the merc primer(92-802878q52) and says it's for gear cases but is gray.
Also, can't remember if I changes the anodes 2 years ago when drive was installed new? Is there anyway to ID them?
thanks as always
Old 04-12-2021 | 03:22 PM
resurrected's Avatar
Magnesium will effervesce if you put vinegar on it, or it will burn hotter and brighter than a meteor entering the atmosphere at night
resurrected is offline
