Trim Tab Oil Usage?
Old 06-07-2021 | 04:31 PM
Default Trim Tab Oil Usage?
Hello everyone! I have Dana 1000 trim tabs on the boat I bought. When I bought the boat the oil reservoirs were half full. After running the boat for several hours they were just about empty. I filled them with steering fluid and after running another couple hours they we down to the refill line on the tank. Fitting are tight and I don't see any excess oil leaking from anywhere so I'm wondering if this is normal and if anyone else has had this problem? Thank you in advance for the help!
Force Fed is offline
Old 06-07-2021 | 05:30 PM
rams are leaking. you just are not seeing it. had to rebuild the same ones on a boat not long ago.
compedgemarine is offline
Old 06-07-2021 | 06:11 PM
ditto. bring them to hydraulic shop or buy a kit to rebuild them yourself.
1MOSES1 is offline
Old 06-09-2021 | 11:39 PM
Yup...rams. The reason you arent seeing it is because you are making rainbows in the water.
lear60man is offline
Old 06-14-2021 | 11:01 PM
Thanks all for the help. That's what I figured but thought I'd double check.
rneabling is offline
