trim tab pump leak
Old 07-09-2021 | 06:29 AM
Active Streak: 30 Days
I had the same issue a couple years ago. There was a tiny nick on the flare of one of the pressure lines. Only leaked when the trim switch was pushed. Only a drop or 2, but over the course of the day it would make a mess in the bilge. Try taking the lines loose and looking for some evidence of a cracked fitting, or other type of seal issue. Where those pumps are mounted, they get bumped often and can develop small leaks. FWIW..
Helmwurst is offline
Old 07-09-2021 | 06:49 PM
Thanks, I'll give the flares on the lines a close look,I am convinced it is probably something I am overlooking or not seeing.
stealthfever is offline
