trim tab pump leak
Old 07-06-2021 | 07:30 PM
Default trim tab pump leak
Have been fighting a trim tab pump leak,(02 29 ft. Fountain 500EFI) fittings not leaking, new tank and O ring, just enough oil in tank to have the tab operate. And the stupid thing still leaks. Does anybody have any suggestions to stop the leak. I hate any oil leak, let alone one that should be relatively easy to fix. Any help would be much appreciated. TIA
stealthfever is offline
Old 07-07-2021 | 05:37 PM
B38
Buy another pump, sell your old one for 1/2 $. Problem solved!
B38 is offline
Old 07-07-2021 | 07:10 PM
Are you seeing the oil inside the boat?
Baja 252 Islander
bajaman is offline
Old 07-07-2021 | 08:18 PM
Yes it leaks down from the pump and puddles at a low point.
Old 07-07-2021 | 08:22 PM
seafordguy's Avatar
Is it the kind with the plastic reservoir?
If so, every one of those ever made leaks. Buy billet or replace every couple years......
seafordguy is offline
Old 07-07-2021 | 08:59 PM
I did replace the reservoir with a Merc. part and new O ring. It is a small thing, but a giant PITA.
Old 07-07-2021 | 10:27 PM
Are you sure its not leaking out of the cap??
Griff is offline
Old 07-08-2021 | 08:49 AM
Dave M's Avatar
Veteran: Navy
Previous boat, I put 12* blocks between the pump mounting bracket and the transom. No more leaks. The angle of the transom was causing the leaks.
Dave M is offline
Old 07-08-2021 | 07:52 PM
I have the ''no leak" caps that were the rage some years back. Two things I am going to try next, put the original caps back on (all 3 caps were changed) but only the one pump is a problem. And second, put dye in the oil to show the leak. We shall see what that reveals.
Old 07-08-2021 | 07:55 PM
The strange and frustrating part is I have the absolute minimum oil in the tank for the pump to operate. I am missing something here.
