Engine guru question!
Old 08-25-2021 | 11:08 AM
What viscosity oil?
bobkatz is offline
Old 08-25-2021 | 11:18 AM
F-2 Speedy's Avatar
Originally Posted by jeff32
when it start to drop in takes like 5-7 seconds
what Im asking is the psi that you refer as normal before it starts to drop, what is the oil temp at this time ? big heavy boat ?
F-2 Speedy is online now
Old 08-25-2021 | 11:28 AM
at 4500 after 1-2 minutes
back to normal when running 4000 rpm or less
If you’re definitely full, you could try running a lower level. Might be whipping up a froth at high rpm.
hogie roll is offline
Old 08-25-2021 | 11:52 AM
jeff32's Avatar
between 50-60 psi
no idea about oil temp
it in a 38 sonic
jeff32 is offline
Old 08-25-2021 | 11:54 AM
jeff32's Avatar
2 weeks to go for boating season so
will take it out and have clearances checked to rule that out
jeff32 is offline
Old 08-25-2021 | 12:01 PM
SB
When apart, Make sure any windage tray or rear baffle that is supposed to be there, is there. Also head oil drainbacks aren’t being blocked partially by anything. And pump screen to pan clearance.
SB is offline
Old 08-25-2021 | 12:26 PM
F-2 Speedy's Avatar
I think you need to do more testing, rule some things out before just saying we're going to pull it out, so its a twin application but the other engine that was not rebuild is ok ? call the shop and get the specs on the bearing clearances, was the crank turned in the rebuild
Old 08-25-2021 | 12:55 PM
B38
Remove oil filter and cut open, if it looks like Christmas in the filter you have junk.
if clean filter, let her eat.
Good luck.
B38 is offline
Old 08-30-2021 | 01:06 PM
When apart, check oil pump pickup tube/foot for being cracked or loose at the oil pump. Could be sucking air when oil level is lower due to being up inside engine.
OPIE272 is offline
Old 08-30-2021 | 04:56 PM
I would try to answer but the explanation of what is going on leaves my head spinning.
ICDEDPPL is offline
