2006 Donzi 38zr Cable Replacement >
Old 12-07-2021 | 04:57 PM
Default 2006 Donzi 38zr Cable Replacement
Hello everyone. I have to replace all my original shifter cables on both motors and was curious how many cables are on one motor? I was told 4, then 3 and now 2 so I don’t know. I need to replace the cables from the shifter itself to the outdrives (all of them). Anyone know that answer or ever have done that project yourself? I was also told the outdrives needed to come off to replace the rear cables. Is that true? Any help would be appreciated. Thanks all.
Jcoombs is offline
Old 12-07-2021 | 05:10 PM
There’s 4 cables that run from the throttle/shifter controller at the helm to the back- two shift cables and two throttle cables. There’s also a shorter cable on each shift plate that runs to the drives. So if you’re wanting to replace all the cables it’s 6 total. The drives do have to come off in order to change the cables from the shift plate to the drive
IGetWet is offline
Old 12-07-2021 | 06:54 PM
Thanks so much for the detailed info. I will pass that along to the boat mechanic for additional info.
Jcoombs is offline
Old 12-07-2021 | 11:41 PM
If your boat mechanic doesn't know how many cables he needs for this job, then he should not be working on paddle boat.
Griff is offline
