Eliminator dragster help
Old 01-23-2022 | 04:11 PM
Default Eliminator dragster help
Is there anyone that can help me find a way to be able to start my eliminator dragster boat out of the water or by using a hose. Thank you very much for all your knowledge and help in the past. It is a 496 stroker’s with exposed engine pickle fork
Jojoegen is offline
Old 01-23-2022 | 04:30 PM
jet or v-drive?
compedgemarine is offline
Old 01-23-2022 | 10:31 PM
Where does the engine get its water normally??
Griff is offline
Old 01-24-2022 | 08:18 AM
jets are feed from the jet pump, v-drives from a pickup usually on the cavitation plate. thats why I asked. there are ways around it but different for each.
Old 01-24-2022 | 12:00 PM
Jet drive
Jojoegen is offline
Old 01-24-2022 | 12:29 PM
Sydwayz's Avatar
Forum Regulator
There will be a water line off of the pump tunnel. You need to put a coupling in that line, that allows you to disconnect from the pump, and connect a garden hose.
Does the engine have a water pump or a crossover on the front?
Sydwayz is offline
Old 01-25-2022 | 10:46 AM
It has a thermostat housing with I believe four hose Inlets not A metal piping that goes from one side to the other
Jojoegen is offline
Old 01-25-2022 | 10:59 AM
F-2 Speedy's Avatar
pictures would sure help
F-2 Speedy is offline
Old 01-25-2022 | 11:33 AM
Check this video out.
SecondWind is offline
Old 01-27-2022 | 09:27 AM
Thank you second wind that was fabulous video
Jojoegen is offline
