-   -   Torque Engineering V12 (https://www.offshoreonly.com/forums/general-boating-discussion/377830-torque-engineering-v12.html)
hogie roll 12-27-2022 05:17 PM
Originally Posted by underpsi68 (Post 4854342)
That 632 has aluminum rods I believe. Not much warranty there lol
I doubt it, it’s a pump gas motor
SB 12-27-2022 05:32 PM
https://www.chevrolet.com/performance-parts/crate-engines/big-block/zz-632
ZZ632/1000 DELUXE TECH SPECS
  • Part Number: 19432060
  • Engine Type: Chevy Tall-Deck Big-Block V-8
  • Displacement (cu. in.): 632 cu. in.
  • Bore x Stroke (in.): 4.600 x 4.750 in.
  • Block: Cast Iron Bowtie with 4-bolt main caps-tall deck
  • Crankshaft: Forged 4340 steel
  • Connecting Rods: Forged steel H-beam
  • Pistons: Forged aluminum 2618 alloy
  • Intake Manifold: Aluminum high-rise single-plane
  • Throttle Body: 4500-style
  • Fuel Injectors: 86-lb/hr
  • Camshaft Type: Billet Steel Hydraulic Roller
  • Valve Lift (in.): 0.780 intake/0.782 exhaust
  • Camshaft Duration (@0.050 in.): 270º intake/287º exhaust
  • Cylinder Heads: Aluminum spread-port; 70cc chambers -RS-X design
  • Valve Size (in.): 2.450 intake/1.800 exhaust,Titanium (5/16-in stem OD)
  • Ignition Type: 58X crank-triggered, coil-near-plug
  • Compression Ratio: 12.0:1 (nominal)
  • Rocker Arms: Forged aluminum; roller-style
  • Rocker Arm Ratio: 1.8:1 (shaft-mount)
  • Water Pump: Aluminum
  • Oil Pan: Steel 8-quart
  • Recommended Fuel: Premium pump (93 octane or higher)
  • Maximum Recommended RPM: 7,000
  • Balanced: Internal
More on it’s unique heads:
https://www.enginelabs.com/features/big-and-tall-chevys-rs-x-zz632-big-block-cylinder-heads-are-huge/
and
https://m.youtube.com/watch?v=s7Y1RS98YQQ
underpsi68 12-27-2022 05:50 PM
Oops sorry, I thought I read they were aluminum. Steel makes more sense.
Twin O/B Sonic 12-27-2022 06:03 PM
They came out w/one same/similar a yr ago but was a drag motor.
Same motor?
hogie roll 12-27-2022 07:09 PM
Same motor?
This is that motor. Not technically a drag motor. Low compression and medium cam lift.
Here’s a more race engine. Near max effort on the standard bbc 4.84 bore space.
https://www.shafiroff.com/chevy-drag-race-engine-pro/632-tunnelram-big-block-drag-race.php
1350hp 632
https://cimg1.ibsrv.net/gimg/www.off...6e1862e61.jpeg
boostbros 12-27-2022 08:24 PM
the new trend in blown promod is 5.30 bore spacing allowing way oversquare big bore, shorter stroke. the engine is 2 inches longer i believe, it uses all special heads and can easily attain 1000ci with all cnc billet products. i dont think they will stop there
iliveonanisland 12-27-2022 09:27 PM
Originally Posted by SB (Post 4854338)
LOL, the COPO Camaro doesn't even have a VIN.
seriously wow had no idea. So they cant be tagged and registered for the street ? That sucks.
iliveonanisland 12-27-2022 09:42 PM
I figured it would be fairly easy to make 1.5hp per cubic in n/a. My 540 does that. But I guess when you get into larger displacement engines it gets more difficult
iliveonanisland 12-27-2022 09:44 PM
thats some seriously expensive hard parts
