First Dyno Complete
Old 01-13-2023 | 08:25 PM
  #131
Full Force's Avatar
Originally Posted by TomZ
Get heat sinks for the sensors. It will help them last longer in a wet exhaust system. Left bank is best to read on your set-up, but while you have everything apart, it may be wise to have bungs added to the other risers so you can swap side to side to see both banks.
you don't run them in a wet system, you weld in bungs in and out of the jacket, at least that's what I did
Full Force is offline
Old 01-14-2023 | 11:43 AM
  #132
Here you go Rookie, I guess this is now shown on a "single"axis"?
PQ290Enticer is offline
Old 01-14-2023 | 11:53 AM
  #133
Full Force, I did have them set up from Eddie Marine to run a single O2 sensor for each engine because originally I was thinking about running fuel injection but in the end decided not to. I'm not sure you could add one after the fact without quite a bit of damage?
Old 01-14-2023 | 12:26 PM
  #134
TomZ's Avatar
He’s not running dry pipes so it’s a wet system. He has bungs welded in on one bank. I was saying to add another bung to the opposite bank so that he could check both for better accuracy. The heat sinks help save the o2 sensors from reversion and water vapor (I know you know this… just responding to be clear).
Heat sink from Innovative:
Amazon Amazon
TomZ is offline
Old 01-14-2023 | 12:32 PM
  #135
TeamSaris's Avatar
Driver-441
Racer
https://www.amazon.com/Innovate-Moto.../dp/B000CO9MFI
We use those. They help a LOT
TeamSaris is offline
Old 01-14-2023 | 12:41 PM
  #136
Thanks guys.
