Sixteen Power Touts ‘Proof Of Reliability’ After Class 1 Season
Any guesses on what happens to the reliability when they go quad turbo on those mills?
Just a guess, I'd say Kaase and any other high level builder is having their own pistons, rings, rods made if they need them for them. Even cranks and bearings, head gaskets.
They have relationships with manufacturers and if money is no issue.
Other proprietary parts I'd guess Mercrury...
I just checked Bams site, interestingly about everything internal in the short block and the heads including the head aren't sold separate except the main bearings.
If I remember right Geico got Kaase involved looking for durability with the QC4V.
Then also seen an interview where Kaase mentioned getting into them.
How much longer then a QVC4?
Keith Atlanta (02-08-2023)
Not to beat a dead horse but if the cam and cranks are the only true one off items that would be why they may be a viable alternative. The aftermarket has really picked up on LS based motors. But its all a guess, who knows if pistons, valve train, rods etc are proprietary or not.
Other than those and the blocks, yeah seems it is all just LS stuff.
The following 2 users liked this post by cheech:
SB (02-08-2023), Wildman_grafix (02-08-2023)
The following 2 users liked this post by Wildman_grafix:
Gimme Fuel (02-09-2023), SB (02-08-2023)
Answers to questions:
Weight is 800 lbs as it goes on the dyno, 1200 lbs marinized. Add whatever the transmission, transom assembly and #6 drive weigh. The race boat had to carry 600 lbs to meet minimum weight for the class. The engines are not thirsty, because they don't have to run the rich AFR that boosted engines do. Length is 46.5" from back of block to front of accessory pulleys. Other than the crank and block, there are other long parts, such as camshaft, oil pan/main housing and dry sump with 7 stages, also a unique double coolant system with two pumps, two thermostats and two heat exchangers.
The following 5 users liked this post by tomcat:
DRAG (02-14-2023), dykstra (02-14-2023), TrippM (02-14-2023), TURBO JET (02-18-2023), Wildman_grafix (02-14-2023)
