Increased cooling for headers question >
Old 02-14-2023 | 12:41 PM
Oh gotcha. I'll check it this weekend. We usually trim it just up until the boat is running the most mph with no tabs and then bring it back down a touch. I'm not trimming it way up at all. Usually about +2 on the gauge. Usually cruise at 45-50 mph. I'm not currently running a sea strainer but definitely installing one before this season. If running a transom pickup into the second input for the strainer won't mess with anything I think I will do it for insurance. I make a lot of 30 plus mile runs at a time fishing offshore. I don't want to constantly be worrying about water getting to the headers. I don't have any issues at all with motor temps but keep discoloring the headers.
Baby J is offline
Old 02-14-2023 | 08:09 PM
My engine guy told me on my old setup that I was blowing water out of the top of the side vents and I should plug the top 2-3 holes. It was fine at cruise. I never ran hard for very long so I let it be but if you are then it's a cheap fix to try
VetteLT193 is offline
Old 02-16-2023 | 09:57 AM
Anyone got a picture that shows how you plug the top few holes on the side inlets? I checked everything yesterday and there's no corrosion at all so I'm back to trying to eliminate it from sucking air from the side inlets.
Baby J is offline
Old 02-16-2023 | 02:52 PM
Mbam's Avatar
Offshoreonly Advertiser
Do you mean you pulled the water fitting as shown in the photo? That can be a real pita to get off. No other way to check it.
There is a service bulletin re the holes. I'll see if I can find it.
It just involves a tap and some pipe plugs.
Mbam is offline
Old 02-16-2023 | 03:03 PM
I cheated. It's really hard to get to with the headers on so I disconnected the hose at the valve and ran a camera down it. There's no blockages or corrosion to be seen at all.
Baby J is offline
