Down-tube mufflers?
Old 07-21-2023 | 11:06 AM
Default Down-tube mufflers?
I will probably get flamed for this but my boat is a cruiser and we spend lots of time just cruising the intercoastal at slow speeds between ocean runs..... did a recent repower to Merc 496 EFIs and they are super loud. Adding in-line mufflers helped a bit but now thinking I need downtube or something under the dive platform. Flappers are about 9-inches above the water.
Anyone have ideas?
Swampy
Swamplizard is offline
Old 07-21-2023 | 12:14 PM
The turn downs are really only meant to be in the water at idle or close idle speeds
Griff is offline
Old 07-21-2023 | 12:56 PM
Get rid of the through hulls and go through the prop via the y-pipe. 496's run fine that way.
techman is offline
Old 07-21-2023 | 02:46 PM
I have arneson drives so will need some sort of J-pipe outside the transome. I re-measure now that boat is in the water - the bottom edge of the flapper is at water level so I wont need much.
Once on-plane I dont care how loud she is
Swampy
Old 07-21-2023 | 03:25 PM
Any of the major marine OEM's carry down turn pipes. Gibson, Corsa, Hardin.
techman is offline
Old 07-22-2023 | 05:45 AM
A friend made some up out of PVC to test dimensions. They actually worked fine for a month while the SS steel ones were being made.
BadDog is offline
Old 07-23-2023 | 03:13 PM
nice - I will try that. How much under water would you Folks recommend I try?
