Originally Posted by IGetWet
(Post 4886110)
Different drives, imco scx-4s, and different lube but I noticed a change in color around 2021 in the Torco RTF, from a deep blue to a green color. Shortly after I lost both drives. Rebuild and still running Torco RTF because that’s what imco swore by, but then they had started making their own lube… This past season noticed drives weren’t shifting good. Pulled drives and found black tarry substance on every surface! Long story short, no longer using junk Torco! Amsoil severe gear.
I don’t have #6 drives, but i googled :) the question and found a a Merc service bulletin on draining/filling VI dry sump drives:
https://holesbaymarine.co.uk/catalog...5DUCNCBFZYGIZQ |
I have owned a cat with wet sump sixes and two cats with dry sump sixes. Torco MTF is what is used on dry sump 6's. It is a manual transmission oil and it is what Mother Mercury says to use. Summit Racing sells it. Buy a 5 gal pail for $220.
Originally Posted by Brad Zastrow
(Post 4886173)
The green mercury stuff would turn real thin and come out like water in my experience, hopefully the new stuff is better .
Originally Posted by PROP STAR
(Post 4886081)
Dry Sump Drive # 6 question what fluid are you using ?? been using Torco MTF for years and the local High Perf speed shop is no longer a torco dealer ..thanks
Originally Posted by Madman7
(Post 4886204)
I have not used in my dry sumps yet but I have heard good things about it. That is until they change suppliers in the quest for more profit as always... I have used the Amsoil 75w-90 marine gear lube in them the last couple of years from my old boat to get rid of it and zero issues looks the same coming out as it did going in. Going forward I will use the Merc racing stuff so the weight matches. |
| All times are GMT -5. The time now is 02:55 PM. |
