Dry Sump Drive # 6 question >
Old 12-02-2023 | 07:49 PM
bencini231's Avatar
Originally Posted by IGetWet
Different drives, imco scx-4s, and different lube but I noticed a change in color around 2021 in the Torco RTF, from a deep blue to a green color. Shortly after I lost both drives. Rebuild and still running Torco RTF because that’s what imco swore by, but then they had started making their own lube… This past season noticed drives weren’t shifting good. Pulled drives and found black tarry substance on every surface! Long story short, no longer using junk Torco! Amsoil severe gear.
Not to derail this subject on #6's, but its crazy how Imco has changed thier minds on using Torco now. Suddenly last year they have their own line of Imco oil and recommend the Mercury oil if Imco is not available. The Imco stuff is way different than the Torco was and cheaper to buy as well,
bencini231 is offline
Old 12-02-2023 | 08:00 PM
SB
I don’t have #6 drives, but i googled the question and found a a Merc service bulletin on draining/filling VI dry sump drives:
https://holesbaymarine.co.uk/catalog...5DUCNCBFZYGIZQ
SB is offline
Old 12-03-2023 | 02:25 PM
Brad Zastrow's Avatar
I have owned a cat with wet sump sixes and two cats with dry sump sixes. Torco MTF is what is used on dry sump 6's. It is a manual transmission oil and it is what Mother Mercury says to use. Summit Racing sells it. Buy a 5 gal pail for $220.
Brad Zastrow is offline
Old 12-03-2023 | 03:11 PM
Mercury issued a service bulletin in 2013 stating their new racing gear oil replaces the Torco MTF. It's used in all their racing gearcases/outdrives including dry sumps. The Torco is still a great oil and can still be used.
oceanoutlaw is offline
Old 12-04-2023 | 09:49 AM
^^ This
Madman7 is online now
Old 12-04-2023 | 10:28 AM
The green mercury stuff would turn real thin and come out like water in my experience, hopefully the new stuff is better .
ICDEDPPL is offline
Old 12-04-2023 | 03:47 PM
Originally Posted by PROP STAR
Dry Sump Drive # 6 question what fluid are you using ?? been using Torco MTF for years and the local High Perf speed shop is no longer a torco dealer ..thanks
Mercurys new 85w90, its gold/ brown in color. Mine comes out looking the same as it went in every oil change.. good stuff!
bigfarmer is offline
Old 12-04-2023 | 06:01 PM
Originally Posted by Madman7
^^ This
This.
I have not used in my dry sumps yet but I have heard good things about it. That is until they change suppliers in the quest for more profit as always...
I have used the Amsoil 75w-90 marine gear lube in them the last couple of years from my old boat to get rid of it and zero issues looks the same coming out as it did going in. Going forward I will use the Merc racing stuff so the weight matches.
Diamond Dave is offline
