Port Side Starter Replacement 496 Twin Engine >
Old 12-22-2023 | 04:15 PM
Default Port Side Starter Replacement 496 Twin Engine
I need to replace the Port Side Starter and access is a nightmare.
From what I can see I need to pull the hoses, the Riser and the Manifold. Might as well replace the knock sensors while I'm there...
Looking for advice on an easier way to do this other than pulling the engine.
Thanks in advance.
Stitch King is offline
Old 12-25-2023 | 09:30 AM
bencini231's Avatar
Thanks in advance.
I had one replaced in a 30 Outlaw we had years ago. There was no way I could have fit in there to get to it, but the shop that did it had someone small enough to reach it without removing a bunch of parts. The $100 in labor cost was way better than me cussing while changing it myself.
bencini231 is offline
Old 12-25-2023 | 10:51 AM
havent done one of those but the last time I changed a starter in tight spaces I put a small flat strap around the solenoid so it held the weight from above so I did not have to hold all the weight from down in the bilge. if you have someone above to lift and lower it so you can just move it into place and start the bolts it is easier.
compedgemarine is offline
Old 12-25-2023 | 11:04 AM
seafordguy's Avatar
Honestly, I’d just pull the motor.
6 bolts to remove drive, 2 bolts to remove exhaust clamps, 10 bolts to remove engine if you have offshore mounts. Raise motor a foot or two, replace starter and lower back down. You can possibly get away without removing grounds, water hoses, etc……
Im an incompetent accountant and can have one out of the boat and on the ground in an hour or hour and a half at the most including set up time.
seafordguy is offline
Old 12-27-2023 | 07:11 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
That's a job I paid to have done on my twin 496HO boat. Fortunately on the 37' Active Thunder, there was room for a little guy to slide under the motor for my port side replacement.
Sydwayz is offline
Old 12-28-2023 | 10:07 AM
Active Streak: 30 Days
^^^ Find a skinny tech with 8' arms!
Helmwurst is offline
Old 01-01-2024 | 07:26 AM
B38
Easy, pull exhaust manifold and riser off. Replace starter and check exhaust for leaks.
Not that bad. Just do it. Or pay $$$$$
B38 is offline
Old 01-01-2024 | 11:38 AM
scarabman's Avatar
^ Agree. Not sure why most seem to feel pulling the engine is the easiest answer?
scarabman is offline
Old 01-01-2024 | 11:48 AM
...as long as no exhaust manifold bolts break off in the block...
Baja 252 Islander
bajaman is offline
Old 01-02-2024 | 02:29 PM
The previous owner paid for this job back in September 2022. I bought the boat March of 2023 and got the receipt.
Fast forward to current time and the reason I'm replacing the starter is the tech left the nut loose that held the terminal lug to the starter solenoid. The lug is arced all to hell and the end of the terminal lug is burned away.
Now I know why my engine was out of alignment back in July and I found the engine mount bolts were left loose. I couldn't figure out why those bolts were never tightened. Until now...
