Bravo Outdrive Help
Old 06-03-2024 | 01:28 AM
Default Bravo Outdrive Help
I have a Maxum 2800 SCR (heavy boat) with an mpi 454 engine. I currently have a bravo 3 with a 2.20:1 gear ratio with 20P props. I blew my upper unit. I currently have a good bravo 1 outdrive sitting in my garage that is currently a 1.50:1 ratio. I did the research and I know I can mate the bravo 1 upper to my bravo 3 lower, but it would change my ratio to a 2.00:1. My question is what will happen to top speed, engine rpm's, hole shot etc. Not looking to go fast, it's not a fast boat, just wanting to get back on the water. Thanks
brianc is offline
Old 06-03-2024 | 05:58 AM
I once replaced the lower half of a bravo 3 with a different ratio on a rinker Fiesta vee 270 with a 5.7. Originally was a 2.2 ratio, but with lower I put on it was somewhere between 1.8 and 1.9. We lost almost 1k RPMs and was much harder to get on plane.
Ryanw10 is offline
Old 06-03-2024 | 01:28 PM
Thanks, that's what I am afraid of. My boat is hard enough to get on plain now.
brianc is offline
Old 06-03-2024 | 01:29 PM
Will a newer bravo 3, with the swept back case, fit on my year 2000 boat?
brianc is offline
Old 06-04-2024 | 12:23 AM
Going from a 2.20 to 2.0 will pull rpms down about 800.
A sweptback upper will work fine
Griff is offline
Old 06-04-2024 | 08:37 PM
Thanks for the info!!
brianc is offline
Old 06-05-2024 | 06:56 AM
I assume that you are going through the lower and not just going to bolt the lower on after the upper grenaded?
Bill Glueck is offline
Old 06-05-2024 | 07:28 AM
Very good point, if the upper grenades there is metal chunks/shavings in the lower
Ryanw10 is offline
Old 06-05-2024 | 02:14 PM
I just bought a newer used complete bravo 3 outdrive (swept back case). I am going to pressure test it when it gets here before installing it, but the guy said it had no issues. I even spent the past two days replacing all the bellows. In total, I'm in to it about $6000 dollars. Got to love the boat life!
brianc is offline
Old 06-05-2024 | 05:34 PM
Is it just me or when a guy says it had no issues, I take that with a grain of salt and think maybe it wouldn’t hurt to have it professionally checked out so to be sure. You’ve spent 6K. Spend a little more so that the 6K was a good buy.
sonicss42 is offline
