Heat exchanger.....it works...lol >
Old 07-07-2024 | 10:38 AM
Default Heat exchanger.....it works...lol
Hello all it been a while since I posted here....some of you may remember...I tried to closed cool a supercharged engine.....giving the short version here for now....bottom line it can be done....598 with whipple supercharger....1070 hp....3 stage water pump...2 to the engine...1 to intercooler....20 percent antifreeze....to water....no thermostat....50 lbs water pressure at wide open ...which is 100mph....fine details....heat exchanger...built by Linco by my spec....40 in long 3 pass.. 5in dia....as mercy would do...just bigger....mezzire circle track water pump on engine...not cheap......water temp 120 at all times....ran 5500 rpm for 10 miles....my wide open run is 2 to 3 miles max....temp 120....hope this helps all......
Old 07-08-2024 | 11:23 AM
TeamSaris's Avatar
Driver-441
Racer
Careful with it mounted lower than the engine. Very hard to purge all the air out of it. We took over maintenance on a boat from long island with a blown up zul engine and that was the cause. Obviously, you arent having issues. Just something to keep in mind. There's a reason merc mounts them up top. Nice job!
TeamSaris is offline
Old 07-08-2024 | 02:32 PM
Thank you....yes I know the boat you are referring too....I can't comment though...I have a expansion tank above the heads....which makes bleeding air out alot easier....
park35 is offline
Old 07-08-2024 | 03:51 PM
TeamSaris's Avatar
Driver-441
Racer
awesome! clean setup for sure
Old 07-12-2024 | 11:09 AM
park35 Thanks for Info. I am in process if rebuilding my dart tall deck non supercharged and planning on a heat exchanger 1/2 system. I also live on long island .Did Linco also make your expansion tank and the mounting brackets on the cooler. Looks Awesome Thanks for sharing.
TwoKs is offline
Old 07-12-2024 | 01:32 PM
TomZ's Avatar
Nice setup!
I'm running 509 CID with factory Merc big block heat exchangers in my old tub, 600 hp NA. The engines run around 175-180 at cruise, but at speeds above 60 mph they're 155-160. I do run thermostats (160 degrees). Love the fact that I do not have to worry about my cylinder heads becoming the sacrificial anodes.
TomZ is offline
