94 Bandit, LS swap?
Old 09-29-2024 | 07:05 AM
This is the info I was hoping to find out. Things I don't know to consider like the great set in the drive, how it's effected by the different platforms. A greatest change wasn't in the cards for this, just taking advantage of what I already had wanting to re-power an old 310 HP 454. I think this hull will go fast and it's not heavy at all. If I remember correctly, it's 3470 dry weight.
Danimal182 is offline
Old 09-29-2024 | 08:44 AM
I don’t think there is a 2.0 gear ratio bravo.
Also that hull wants bow lift. The light weight engine package won’t be helping.
tmmii is offline
Old 09-29-2024 | 09:10 AM
If I don't keep it trimmed down, keeping the nose a down little and keep most of the hull in the water, it porpoises a lot unless you're all in going faster.
Old 09-29-2024 | 10:24 AM
Veteran: Reserves
This is the biggest problem for LS marinisations. Old TRS have separated gearbox.
plavutka is offline
Old 09-30-2024 | 03:52 PM
TRS drives also have a 1.5 reduction built in.
LS engines don't 'need' a 2:1 reduction. It's all about the package of what you're trying to achieve. Large diameter props required for big reductions have a larger drag...that cancels out any benefits at speed.
Typically, porpoising is from a stalled out bow lift scenario. Lots of prop options to help reduce bow lift, or lift the stern.
In this case, having less weight astern may smooth out the porpoising.
Tartilla is offline
Old 09-30-2024 | 04:05 PM
Interesting, I can see how that would help. I will say this hull loved the Rev 4 I had. As for the LS I wouldn't be scared of RPM, but my understanding is the outdrive can only take so many RPMs.
Old 09-30-2024 | 11:02 PM
Interesting, I can see how that would help. I will say this hull loved the Rev 4 I had. As for the LS I wouldn't be scared of RPM, but my understanding is the office can only take so many RPMs.
​​Just looking to confirm what 'office' means? I suspect Voice to text or auto-correct is messing up.
Assuming you mean the drive...drives do have rpm limits, but 5500-6000rpm isn't too hard on them if setup well.
Drives are rated in torque. Get the rpm up...for a given tq, your safe HP is now higher. Broaden out the max rpm/speed, you also have the issue of increasing your cruise rpm. But the drive is working less and loaded less with a lower pitch prop..and a bit more cruise rpm.
Trim tabs can solve the porpoise issue. Trim will also help, but if you move the trim out of optimal to account for the hull, the prop becomes less efficient.
Tartilla is offline
Old 10-01-2024 | 06:04 AM
Yes I meant outdrive, I didn't proof read before hitting send. I was always told 5200 rpm for my drive. Now that being said it opens me up to more prop options.
Old 10-01-2024 | 06:05 AM
What do you mean, set up well? Mine is still factory internally from 94 with yearly fluid changes since I've had it.
