632 1000 hp crate! Ready or not?
You have some good advice here. Crate motors are built for a car that will experience full throttle for seconds at a time. Marine engines are under heavy load for hours at a time. Odds are high the engines will not live for all the reasons listed on the posts.
I understand this with tolerances on large BBs with cast iron blocks.
What about the LS3-6.2, which has an aluminum block and 80 hp/liter, close cooling sistem? Is it also dangerous to leave automotive tolerances there between the piston and the cylinder?
So far I have done about 200 hours, of which about 15% wot-6,000 rpm, the rest mostly at 4,500 to 5,000 rpm, but a reall comment from the "old saylors" on this forum would be very welcome.
Purpose build high performance marine engines pretty much need to be on their bearing specs.
Your 4500-5000 rpm is on the high end of a cruise rpm. Hard to say how your bearings are making out. You never really know unless you open them up and check/adjust etc. That is the point.
For what is supposed to be a hand built GM crate engine, I would expect a build sheet with bearing clearances.
Cut the oil filter open(if you haven't) and check if there is any metal on the next change.
