VR1 with M6
Old 12-26-2024 | 01:23 PM
Cool boat. Seems like the M6 is way overkill, though, isn't it? an XR or SC would have been sufficient, wouldn't it? And way cheaper?
Thanks. Brad.
Brad Christy is offline
Old 12-26-2024 | 02:36 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
That thing throws more water than all 3 of my jet boats, COMBINED, I think.
Sydwayz is offline
Old 12-26-2024 | 04:29 PM
it gonna be used in the new gator movie.nice rooster tail though.
wonder what the top end is on it?
sutphen 30 is offline
Old 12-27-2024 | 09:32 AM
Originally Posted by Indy
28' for $300, we've reached a new level of unreal.
A buddy just bought a new 18 foot flats boat, with electronics, power pole and trolling motor it was well into the 6 figure range.
This Velocity is 300K USED, wonder what it sold for new.
Thanks. Brad.
Mercury will not sell the 700's with a XR drive. Remember this was a OEM build.
Wildman_grafix is offline
Old 12-27-2024 | 09:12 PM
Well how fast does a 32 pitch go? Are M6 one typical ratio?
hogie roll is online now
Old 12-27-2024 | 10:37 PM
97-110mph,,depending on slip and gear ratio.
Old 12-28-2024 | 11:30 AM
What I would guess. A number of single velocities with superchargers are around that.
This being a carbon VR-1 gives it a big advantage though.
Old 12-29-2024 | 02:18 PM
Thanks. Brad.
NO!
Read all the threads on XR gear failures.
That # 6 on there is pure peace of mind.
What he said.
The 700's used to get NXT drives. I think they are discontinued.
cheech is offline
Old 12-30-2024 | 06:20 AM
Originally Posted by cheech
NO!
What he said.
Cheech,
So, what's an M6 cost? More than an SCX? Is there just nothing between the XR and the M6? Is the SC a parallel to the XR?
Thanks. Brad.
Old 12-30-2024 | 08:34 AM
Cheech,
Thanks. Brad.
Two things Brad,
As far as I know as a OEM builder Mercury will not sell you a 700 with no drive, I THINK. I could ask Scott if it really helps.
The SC is the XR gears in a stronger case, so you still get the pitting and failure.
The SCX has larger gears, cone clutch etc. But still uses a cone clutch means for forward reverse. It is a very good drive if you have a bravo boat that you have upgraded power since you do not have to move the motor, change cutout things like that.
M6 uses a transmission. Also the whole helmet and such is much much stronger and I think the dry sumps use less power then a SCX.
