Filter MAG??
Old 12-17-2002 | 02:04 PM
If you have a man hole cover stuck to the bottom of your car, you might want to consider a weaker magnet.
Gary
Gary Anderson is offline
Old 12-17-2002 | 02:05 PM
CigDaze's Avatar
Possible dissimilar metals corrosion?
Periodic moisture in the oil.
What's the magnet made of, Neodymium Iron Boron? Pan?
Also, make sure you have the clearance.
CigDaze is offline
Old 12-17-2002 | 02:11 PM
cigarette1's Avatar
Member #2 ....Jeeezz
They are Neodymium Iron Boron 1"x.25". (clearance, no problem)
Steel pan - I'm thinking of placing a layer of plastic between the pan and magnet to prevent any corrosion.
What is the concern for moisture in the oil?
The magnet are small, but strong as a MOFO.
G
cigarette1 is offline
Old 12-17-2002 | 02:17 PM
CigDaze's Avatar
Just the same reason, depending on the magnet material and how it would react to moisture....Probably not a big concern.
CigDaze is offline
Old 12-17-2002 | 02:21 PM
cigarette1's Avatar
Daze ... I am going to put them on the outside of the pans.
Old 12-17-2002 | 02:25 PM
CigDaze's Avatar
Oh...Then what happens if it falls or gets knocked off...That big clump of metal all of a sudden gets turned loose. Could be bad news.
I don't know about the boat but on my Ford, the magnets are on the inside of the pans, Both Tranny and Oil.
CigDaze is offline
Old 12-17-2002 | 02:32 PM
cigarette1's Avatar
Good point ... But, as strong as these MOFOs are, I don't see how they could come off without something actually knocking it off.
If they were to come off, the "clump" of metal would have to pass thru the filter before it gets to any bearings. I would hope that "clump" wouldn't be too big, know what I mean
G
Old 12-17-2002 | 02:34 PM
Wally's Avatar
Were doomed!
I just put mine on the filter its self! No chance of it getting knocked off and if it still is a concern just place a piece of duck tape over it!
-Wally
Wally is offline
Old 12-17-2002 | 02:39 PM
CigDaze's Avatar
I know exactly what you mean.
Fingers crossed for No Clumps
CigDaze is offline
496mag
03-11-2008 01:57 AM
zimm17
0
08-03-2005 12:21 PM
JeffGrice
11-06-2004 10:40 PM
voodoo
2
08-26-2003 12:04 PM
In2Deep
3
06-18-2002 03:18 PM
