What is a Baja built with? >
Old 05-16-2025 | 04:00 PM
Default What is a Baja built with?
I’m attempting my first fiberglass repair on the bottom of a 2007 Baja Islander 208. Been trying to do as much research as I can before starting this project and I’m learning that epoxy and polyester resins don’t get along very well. I’m gonna be finishing the repair with gel coat so I know I need to use polyester resin for gel coat to bond. Does anyone know if Baja boats are built using polyester or epoxy resin?? And if it’s epoxy will have issues using polyester? Thanks
Micamato is offline
Old 05-16-2025 | 04:24 PM
cougarman's Avatar
I would like to think Baja used (vinyl ester resin) which is a step up from Poly
(I'm Positive they didn't use Epoxy)
cougarman is offline
Old 05-16-2025 | 04:49 PM
F-2 Speedy's Avatar
Contact on FB, he was there for years
Dave Leonhardt
https://www.facebook.com/DaveWLeonhardt
F-2 Speedy is offline
Old 05-16-2025 | 05:05 PM
Dave Leonhardt
thanks. I reached out to him and he didn’t deal with that aspect of the boats and is not sure
Micamato is offline
Old 05-17-2025 | 04:13 AM
you are correct.
tmmii is offline
Old 05-17-2025 | 06:02 AM
Reading my various BAJA brochures, they say vinylester resin.
Baja 252 Islander
bajaman is offline
Old 05-17-2025 | 10:00 AM
Originally Posted by tmmii
you are correct.
thank you
Micamato is offline
Old 05-17-2025 | 10:38 AM
You can use epoxy on cured Vinylester. If you do, you will need to use epoxy for all future repairs in those areas. Epoxy will bond to cured vinyl but vinyl will not bond to cured epoxy. I have witnessed this dozens of times.
Joe
JPEROG is offline
Old 05-17-2025 | 05:24 PM
I think you can use poly on vinylester too???
Twin O/B Sonic is offline
Old 05-18-2025 | 12:02 AM
Joe
Best to just keep using vinylesrer then?
Tartilla is offline
