empty tank
Old 11-22-2025 | 06:28 AM
Originally Posted by scippy
So my fuel tank is dry after pumping all old fuel out ...any suggestions to avoid condensation for winter storage.
Ayuh,...... Don't worry 'bout it,.... It'll be just as dry then, as it is now,......
Bondo is offline
Old 11-22-2025 | 07:26 AM
Active Streak: 30 Days
Why can't you just put some tape over the vent ?. I don't see an issue with that unless your tank is filled to the top of the hose and needs to expand and contract. JMO
Helmwurst is offline
Old 11-22-2025 | 08:07 AM
I’ve been doing the same thing seafordguy does for the last 35 yrs. I fill up close to the end of the season, use it a few more times, usually leaves me with around half tank. Put stabilizer in it, store it for the winter and top off beginning of summer with fresh fuel.
outlaw511 is offline
Old 11-22-2025 | 08:56 AM
I always drain the tank(s) before winter storage. No sense letting perfectly good gas sit when I can use it in cars, toys, and power equipment. One spring, just for grins, I tried pumping the dry tanks again to see if any significant condensation gathered. None, bone dry.
Fresh fuel in the spring. Never had a problem in 25 years.
techman is offline
Old 11-22-2025 | 10:16 AM
Veteran: Navy
Originally Posted by 496blower
I fill with alcohol free gas some stabilizer run the engine do oil change and good to go for next summe, unfortunately alcohol free gas over a buck a gallon more, never had a problem
ditto
I fill 91 octane non ethanol
Add fuel stabilizer
I have to open it up maybe
During winter as my fuel guage stopped working right aftet i filled it up
hoping just a wire came loose
Have not been mobile enough to chase it
powerboatr is offline
Old 11-22-2025 | 02:18 PM
Originally Posted by bajaman
I have never, ever, in 50 years of boating heard ANYONE drain a tank on a boat for storage...
He`s a little special
ICDEDPPL is offline
Old 11-23-2025 | 09:07 AM
Default Condensation
If there is enough condensation for it to matter, you will be able to pump the water out before filling with fresh fuel in the summer.
Markus is offline
Old 11-23-2025 | 11:53 AM
scippy's Avatar
just to understand, Gas was drained because it was old not because it was drained just for storage. I even considered polishing the old fuel, but for $750 to do so, I drained it into 50 gal. tank.
scippy is offline
