I need some ideas
Old 02-19-2026 | 08:55 AM
Active Streak: 30 Days
Originally Posted by ICDEDPPL
That dude`s charges will make my nose bleed.
I got a quote on upholstry and almost fell over.
I`m on a budget. and it`s not $20k
Yes, he is, but it will look factory. BTW, upholstery work has gotten ridiculous. I just installed a driver seat yesterday for an older friend in his MB suv. He had it done at an upholstery shop in Springfield MO. All they did was replace the bottom panel in the seat, we removed it, he drove it to them and picked it up a week later and they charged him 600.00
Helmwurst is offline
Old 02-19-2026 | 09:45 AM
SB
Vehicle repair rates around here are$150-$195/hr. 3 hrs goes by fast, thus $600 too !
That said, i don’t know what upholstery rates are now a days. But…everything seems brutal
SB is offline
Old 02-19-2026 | 10:43 AM
Thumbs up
Originally Posted by lake p.a.l.
Buds old Skater he put the push in cleat receptacles & had a plastics company make 2 windshields. So he had 4 small holes to drill, install the clean small stainless cleat receptacles, & put the windscreens in when he wanted them.
Worked great
Thats exactly what I had in mind.. just trying to figure out how to adapt the cleats to the windshield. Cliffs cleat seems like the best choice so far .
ICDEDPPL is offline
Old 02-19-2026 | 11:05 AM
SB
Just throwing something out against wall to think about. Few boats i work on use these quick releases for their biminis.
https://www.overtons.com/-quick-rele...ct5mWKJAbeU_C0
SB is offline
Old 02-19-2026 | 11:20 AM
Dan,
You may have to have something made. Not a shameless plug, but I've done this sort of thing a thousand times. An adapter, if you will, that has provisions for the receptacle on one end, and a bracket that the windshield on the other. Been there, done that. Look at how the old inverted wind deflectors were on the old skool daycruisers were mounted, just with a stem for the receptacle instead of screwed to the deck of the boat.
Thanks. Brad.
Brad Christy is offline
Old 02-19-2026 | 12:02 PM
I`m lucky I have a local lady that`s good and reasonable.
I bought all the material . Material is cheap btw. yard of vinyl is $40-70 ... $150 for marine alcanta. A little over $2k in material and she charged me $4k to redo the whole interior.
Came out great .
ICDEDPPL is offline
Old 02-19-2026 | 12:04 PM
Dan,
Thanks. Brad.
I`m in, let`s make some cool stuff ! . I`ll text ya.
ICDEDPPL is offline
Old 02-19-2026 | 12:18 PM
Well guess that angle of the back seat complicates things. I don't remember it being there!
Take off that top piece and buy a cheap piece of plywood or whatever cut to fit and bolt it up to some of the existing holes. Throw some people in the back and run it for proof of concept. Easy-peasy. I'm sure Brad could make some multi angled brackets to bolt it behind the seats if you didn't want it super easy to remove or drill anything.
Diamond Dave is offline
Old 02-19-2026 | 01:55 PM
I wouldn`t want it permanent, someone would trip over it and faceplant right on top of the T handles and break their face , we cant have that lol
If this works I know who the next customer will be .. DAVE!
ICDEDPPL is offline
Old 02-19-2026 | 02:27 PM
Thumbs up
Originally Posted by LakeBoat4
Dan,
This may not be the easiest way to go but will work just as you are talking about. The acuators need to be mounted in back of the seat bulkhead and a slot cut in it for movement, plastic wind deflector in front between seat back and bulkhead. I would use two of them with the control unit for even movement. 22 lbs each or more force will work. Just the more weight the slower they move. I am using thers for a (raise & lower) windshield on my new Cat build, 3 section pieces. Also for raising the engine hatch, 24 inch traval with controller.
https://www.firgelliauto.com/collect...r-actuator-12v
That is engineering above my pay grade ,however I found an actuator that is 2" per second vs mine at .5"/second. We have fenders/ropes in the bilge so a faster open/close will be much better .
https://www.firgelliauto.com/product...nt=11256348422
ICDEDPPL is offline
