AXG3 Update
Old 01-15-2003 | 08:22 AM
Tres's Avatar
Default AXG3 Update
Hers a update for you guys, The engine room rigging is just about complete and motors will be reinstalled. Just waiting on some diamond plate to come back from the anodizer.
Tres is offline
Old 01-15-2003 | 09:16 AM
later's Avatar
what are they white hoses that go through the bottom up the transom
later is offline
Old 01-15-2003 | 09:22 AM
JUSTONCE's Avatar
Prolly a low air p/u for the blowers
JUSTONCE is offline
Old 01-15-2003 | 12:18 PM
Tres's Avatar
Default It is...
That is used to revome the low pressure from the notched transom. Primarely it's an airv ent.
Tres
Tres is offline
Old 01-15-2003 | 02:02 PM
cigarette1's Avatar
Member #2 ....Jeeezz
A Ventilated Notch .... very cool.
I've always thought of directing air to the transom area to reduce the vacuume there. That should probably net at least the same effect as the vented notch, if not more. Have you tested anything like that.
cigarette1 is offline
Old 01-15-2003 | 02:53 PM
later's Avatar
i thought that was what that was for, my 98 fountain has two hoses for the same reason but the hose is what appears to be much larger the size of my water intake hose.
thank you
later
later is offline
Old 01-15-2003 | 07:02 PM
JM94's Avatar
Default Absolutely..
We have tested it on several boats including all my F-2. It also aides in extended plaining of the boat. It does ease the low pressure.
JM94
JM94 is offline
JM94
02-14-2003 10:54 AM
Tres
01-29-2003 03:14 PM
Tres
12-13-2002 12:55 PM
JM94
12-05-2002 04:32 PM
Tres
11-14-2002 02:59 PM
