OT-Question for GM techs
Old 02-26-2003 | 02:04 PM
Wally's Avatar
Were doomed!
yea....and dont forget about those glove box metering valve's sticking!!! :P
-Wally
Wally is offline
Old 02-26-2003 | 10:00 PM
cartman
Cord check your fuel pressure it should hold even when the pump stops running if it drops off you have internal leak some where. presurise the fuel system by running the pump key on engine off and check fuel pressure should be 55 to 60 psi then crimp off the return line and feed at the rubber part of the line underneath then with the system pressurised see if it holds pressure. If the pressure goes down with both clamped off your leak is under the intake possibly craked fuel lines to the spider commonly missed. if it holds with them clamped off your leak is in the tank posibly a fuel dampner which is between the pump and sender I always replace them with a pump because they leak. Also is the pump priming the fuel rail called a 2 second run? I am not figuring in pump and spider because they have been replaced. let me know if you need any more info it's hard to explain here. Are you shure its a fuel problem? check spark coil wires are common also.
Old 02-26-2003 | 11:34 PM
Playn's Avatar
What year s-10? Sounds electrical to me. How about the fuel pump relay??
Playn is offline
Old 02-27-2003 | 07:08 AM
Offshore Addiction
maybe playn might be kinda correct,I had a 944 that would start and go to work and run fine,but if it got extremly cool or extremly hot out that ***** wouldnt start for nothin,no fuel pressure,they took the pump out and checked it over and over again,gotta love those car dealers,the dealers answer was that I bought a porcshe and there not suppose to start all the time,so while I was over in daytona that som***** wouldnt run,had it towed to a garage that a freind of mine used to work at and they dug deep into the car and found everthing working fine,started right up,but the guy wasnt stupid and finally found the fuel pump relay had a burnt terminal in it and when it got hot or cold that terminal wouldnt make contact,he soldered that bad boy up(coundnt get any parts on late saturday) and it never did it again....ended up gettin rid of it finally after a dope dealer rented a house across from mine and his customers kept runnin into the rear quarter panels,nothin like gettin up at three in the mornin with some guy a f-up with no insurance......now I own that house to!!!!
Old 02-27-2003 | 07:55 AM
Official OSO boat whore
I had previously replaced the relay, just on a whim. It hasn't made a difference. I'm thinking that I need to install some sort of test equipment so I can try to track this thing. Maybe jury rig up a pressure gauge and a amp meter.
Cord is offline
NOMOGOFAST
8
07-24-2007 01:47 PM
Sean H
Nor-Tech
12
03-05-2005 12:28 PM
dyno
01-20-2004 06:26 AM
formula31
24
05-07-2003 07:55 AM
xtremeracingf1
02-27-2003 07:39 PM
