prop help
Old 04-16-2003 | 04:42 PM
MY OBSESSION
Question prop help
I'm looking for help on where to start choosing a prop. I have a 25' obsession vortex (stepped tunnel hull) running a 525sc thru a bravo 1 drive (not sure what ratio). When I bought the boat from the dealer last fall they just slapped on a mirage 3 bladed prop (which I will use as a spare) and sent me on my way. Should I be looking for a 3, 4, or 5 bladed prop? Should It be lab finished??? I am expecting 80+ mph.
Old 04-16-2003 | 10:58 PM
kathycool's Avatar
Julie @ Throttle up was very helpful for us............
kathycool is offline
Old 04-16-2003 | 11:37 PM
Hot Duck's Avatar
I agree. Call Julie and Matt at Throttle-Up. They are easy to work with and will get you on the right track.
Throttle-Up
(877) 842-6855
www.throttle-up.com
Lynch Mob Racing (V-4)
Hot Duck is offline
Old 04-17-2003 | 06:15 AM
HOUSTONPROP's Avatar
Question prop help from others
I am sure there is some board members that have some good imput but we need alot more info as what pitch mirage prop you are running and rated w.o.t. rpm on motor? also how is the prop working now does it have cavation on take off or when turning? does it porporise? midrange? are you looking for a smoother ride or to much bow lift?/the pitch is stamped usually on the side of the hub barrell/Darin
BUT YOU STARTED ASKING IN THE RIGHT PLACE YOU CANT GET BETTER INFO THAN OFFSHORE ONLY.COM
HOUSTONPROP is offline
Sick Stinger
Velocity
9
02-07-2008 11:39 AM
FlyFast
1
08-06-2004 10:22 AM
boatinbill
07-26-2002 09:58 AM
MIKEHTMSR24
07-22-2002 03:18 PM
MIKEHTMSR24
0
07-22-2002 01:40 PM
