Trs Problems...........help!!!! >
Old 05-12-2003 | 05:41 PM
WHITE-DIAMONDS's Avatar
Default Trs Problems...........help!!!!
Took the Excalibur out today for its initial run to open the season and boom already have problems. First started noticing smoke near the tranny area on starboard side, then stopped engine. Checked all fluids and hoses, every thing looked perfect. Started it back up and started cruising, then weird sensation, figured it would not go into drive, forward nor reverse. All cables were checked and even tried to to shift it manually, no go. It is a Mercrusier E type TRS drive, is this a clutch driven drive? My mechanic went with me while we were out, but he is not all too familiar with working on TRS drives. He was going to look in his manual and try and figure out some trouble shooting problems like this.
Any help would be greatly appreciated, I was planning on starting the season this Saturday, but it does not look like it is going to happen.
Spencer
WHITE-DIAMONDS
WHITE-DIAMONDS is offline
Old 05-12-2003 | 06:41 PM
mfb357's Avatar
sounds to me you may have lost your tranny. It will go before the drive will, they are very sensitive to low fluid level. Good luck
mfb357 is offline
Old 05-12-2003 | 06:58 PM
That's the weird thing, fluid was full as can be, actually a little too full and very good shape.........??????
Old 05-12-2003 | 07:06 PM
David's Avatar
sounds like a 215E, and it does have an electrically operated clutch. I would have to dig through my stuff for info, but can't get to anything right now. My garage is packed full of the kid's tools and other s--t.
David is offline
Old 05-13-2003 | 06:52 AM
Audiofn's Avatar
Charter Member #232
No clutch on the mercruiser tranny. Sounds to me like you may have broken your pump. That is real common on those things. If you want give me a call and I will tell ya what I found with mine. I should be in cell range at aprox 9:00. (978) 985-0639
Jon
Put your best foot forward!
Audiofn is offline
Old 05-13-2003 | 09:00 AM
buckknekkid's Avatar
Default call BAMM
try Mark
buckknekkid is offline
Old 05-13-2003 | 12:02 PM
Doller Offshore
Default Call John Klumpjan
Call John, 800-376-1616 or 954-463-9988. He is an expert in all TRS / Trans models, he can help you. Press "O" and ask for him.
Doller Offshore
Old 05-13-2003 | 12:14 PM
lucy's Avatar
riggs marine melvin tell him lucy sent you 920 872 2728;;;;;;;;;;;;;
lucy is offline
jeff1000man
02-27-2007 09:45 AM
chuckgo6
7
07-28-2006 12:12 PM
stageharbor
5
06-22-2006 08:27 AM
