View Poll Results: What oil?
Royal Purple
23
11.79%
Mobil One
112
57.44%
Dyno Oil
15
7.69%
Other Synthetic
45
23.08%
Voters: 195. You may not vote on this poll
What oil are you running?
Old 04-23-2004 | 09:11 PM
  #81
CAP071's Avatar
Jiffy lube I always wanted to own 1 and employ babes in Bikini's
CAP071 is offline
Old 04-23-2004 | 09:48 PM
  #82
LPA2106
..now that's an original thought!
Old 04-24-2004 | 07:35 AM
  #83
CAP071's Avatar
I hung out with a group of girls in college that were hair dressers. I kept telling them to have Bikini day. wash and cut hair in high heels and bikini's. They all laughed.
I told the same thing to these women on my mail route when I was a mailman. They tried it! They had a line out the door that day. They gave me a case of beer as a Thank You. I said keep your beer I want a free wash cut and blow job .............
CAP071 is offline
Old 04-24-2004 | 04:22 PM
  #84
LPA2106
yea..beer don't cum in the flavor you were looking for does it?
Old 04-24-2004 | 04:28 PM
  #85
traviss's Avatar
valvoline VR1 40 wt in the mouse
traviss is offline
Old 04-24-2004 | 04:32 PM
  #86
LPA2106
hey Mr. Capo.....bikini's eh?
Old 04-24-2004 | 05:32 PM
  #87
traviss's Avatar
taaaaasssstttyyy
traviss is offline
Old 04-24-2004 | 09:00 PM
  #88
CAP071's Avatar
Thank the man that invented Bikini's
CAP071 is offline
Old 04-25-2004 | 06:19 PM
  #89
LPA2106
AMSOIL 20W50 FULL SYNTHETIC WITH ADDITIVES
5 GAL $25.00
AMSOIL OIL FILTER $ 11.95
AMSOIL RECOMMENDATION FOR CHANGES:
In marine craft and occasionally used gasoline engines, change oil at three times the engine manufacturer's recommended drain interval or one year, whichever comes first.
SO FOR EXAMPLE MERC SAYS 25 HOURS ON A 525 EFI X 3 = 75 HOURS OR SEASONALLY FOR MOST APPLICATIONS.
ORDER FROM AND DELIVERED UPS
http://www.amsoil.com/distribution_centers.htm
I AM COMFORTABLE WITH THEIR RECOMMENDATIONS...IF YOU RACE OR RUN VERY HARD THE THEY SAY CHANGE AT RECOMMENDED INTERVALS WHICH IN THIS CASE WOULD BE 25 HOURS...I CAN MAKE IT SEASONALLY WITH NO PROBLEMO'S
I AM HAPPY WITH RP BUT THEY DO NOT RECOMMEND THIS MUCH OF AN EXTENDED DRAIN INTERVAL...THE "S" ENGINE MANUFACTURER COMPNAY DID NOT LIKE RP BECAUSE THEY SAID IT DID WIERD THINGS WHEN MIXED WITH GAS...BUT COBRA USES RP....MOST EVERYBODY LIKES AMSOIL....NEVER HEARD A BAD WORD...SOME THINK MOBIL 1 IS HARD TO CLEAN IN THE BILDGE AND DOES NOT RECOMMEND EXTENDED INTERVALS IN MARINE APPLICATIONS....
Old 04-25-2004 | 06:28 PM
  #90
LPA2106
AMSOIL SYNTHETIC MARINE GEAR LUBE
80W90 MEETS MERCURY HI PERF SPECS MIL-L-2105D AND AUTO SPEC GL4 AND API MTI NOT RECOMMENDED AS A REPLACEMENT FOR APL GL5 PRODUCTS
Their are three API service categories for gear oils.
API-GL1, API-GL4, API-GL5.
Most outboard manufactures recommend API-GL5 gear oil for their lower units. API-GL5 gear lubricants are for both mechanical shift units calling for type B gear oil and electrical shift mechanisms calling for type C gear oil (only the viscosity value will be different for each application)
$ 6.00/QT
REDLINE IS GL5 APPROVED SO I WOULD GO WITH RELINE GEAR LUBE AND AMSOIL ENGINE OIL
RECOMMENDED TO CHANGE IN LOWER UNITS PER MANUFACTURER'S SPEC..SO NO EXTENDED RECOMMENDATIONS FOR DRIVES...MAKES SENSE...SO CHANGE IT EVERY 25-50 HRS...
