I may be done boating for the season. >
Old 06-22-2003 | 08:52 PM
  #31
definately not a engine guru... i know enough to get in trouble... but seems like i've read somewhere that most of todays ignitions... just quit working at 9.5 volts..... no matter what... starter still works but no fire...
Don
chromecat is offline
Old 06-22-2003 | 09:03 PM
  #32
Waterfoul's Avatar
Gone Fishin'
Craig, thanks for the blast across the lake!! But it's just wrong that Ryan got to go faster than I did!!!! LOL!!!
Maybe at some point this week I'll feel like messing with my boat. I'm soooooo burnt out on fixing it.
Waterfoul is offline
Old 06-22-2003 | 09:27 PM
  #33
Foul, when reading the thread title, I though "Oh no, he's used up the whole world's supply of PS belts!!!!!!! Glad it is not anything as serious as that!
MNFastBoater: Great to see you are still with us. Missed you at LOTO over Memorial Day.
Chart is offline
Old 06-22-2003 | 09:28 PM
  #34
Whitey's Avatar
It was nice seeing everyone again. Foul it does not sould like anything real serious but, I know how a person can get burned out on a boat. Just take a break and look at it later in the week.
Dwight
Whitey is offline
Old 06-22-2003 | 09:43 PM
  #35
Allan4
If the alternator does not do the trick, I'd look into the ign box. Sounds like a typical puking of an ign box or a coil. Expecially if it fired back up after a short while. Eventually it will just crap out totally.
The motor will run on just a battery (think of a drag car) but eventually drain itself to the point where it cannot make enough spark.
Good luck, don't get frustreted, we've all been there.
Old 06-22-2003 | 09:44 PM
  #36
Rambunctious's Avatar
come on ol' buddy, pick that chin up now. wipe the tears........
you can do it.
i wanna hear those famous words from you
now what are they???? come on... you can say it.......
come on, say it .....
Rambunctious is offline
Old 06-22-2003 | 09:45 PM
  #37
Waterfoul's Avatar
Gone Fishin'
Rob, I can't say it until I do it. And right now, I just don't feel like it.
Old 06-22-2003 | 09:52 PM
  #38
traviss's Avatar
Nice seeing you boys on saturday
Whitey.. Nice looking boat, maybe next time we get together you'll have to take me for a spin
Mr vette Nice meeting ya and seeing your boat, sweet setup and it runs like a raped ape
Foul... thanks for the towel soaked with beer it smelled great this morning LOL! It was a pleasure having you ride with me. My back sure hurt this morning..
Travis
traviss is offline
Old 06-22-2003 | 11:07 PM
  #39
Bulldog's Avatar
If the batteries were hooked up in parallel without an isolator or battery switch was set to both/2, the bad battery will load down the good battery AND the alternator. This means that you may have only had 9 or 10 volts while running, with the alternator working very hard to charge up the batteries.
If the combined pair was at 10 volts, for example, and you try to start the engine, you would probably be lucky to have 6 or seven volts while cranking. A solid state ignition probably has a minimum voltage, and if you go below that it will not make sparks. I would have BOTH good batteries checked on a load tester AND check the alternator. Yes, you should be able to run for a while with just batteries.
Bulldog aka Ronnie
Bulldog is offline
Old 06-23-2003 | 08:11 AM
  #40
Official OSO boat whore
Although it proably gave a scare, it sounds like you're going to get off pretty easy. Install that new alternator and go boating!
Cord is offline
