Like Tree0Likes
Check Those Bilge Pumps!
Old 06-22-2003, 10:07 AM
Charter Member # 1215
My Boats: flying,boating
Default Check Those Bilge Pumps!
AFTER 3 DAYS OF SEVERE RAIN WENT DOWN TO CHECK OUT BOAT, HAD TO TURN ON PUMPS FOR 5 MINUTES, SOMEONE HAD TURNED OFF SWITHCHES. SUGGEST TO ALL TO CHECK
topgunrcf is offline
Old 06-22-2003, 01:24 PM
Kentz
Your pumps should wired "hot" regardless of the batt, switches
Old 06-23-2003, 10:00 PM
My Boats: Velocity 41'
Default Bilge Pumps
I have a pump problem right now that I worked on today with a friend. My float switch has stuck and runs all the time. It is separate from the pump but is not the standard flip up switch. It has a float and diode built-in. Anyway took it apart and had to cut the wires to disconnect power from it, now the other pump is running. For sure though what the problem is, but the only way to cut them off is to unhook the battery cable. If the battery switches would cut them off, and someone mistakeingly turns them to off, and your boat took on some water, well, you know the rest of the story. All bilge pumps should wire straight to the battery. Of course they will also have a manual switch on the dash
Steet is offline
fountainguy214
Wanted
3
01-27-2008 08:51 PM
Phazar454Mag
05-20-2007 04:53 PM
Raypanic
6
01-06-2003 11:00 PM
Low Rider
Sunsation
6
06-03-2002 11:03 AM
Rich36PC
2
03-11-2002 10:05 PM
