Like Tree0Likes
Bravo won't go into reverse?
Old 06-30-2003, 04:03 PM
Mad Hatter
Default Bravo won't go into reverse?
I have a foot throttle with a shifter where a normal throttle would be. THe boat had a cheesy quiksilver shifter on it but that was falling apart when I bought the boat and Finally broke putting it into reverse. No I just have a anodized shifter from teague. THe boat was always hard to get into reverse but this year I can harldy get it to go in at all. I have to work the **** out of to get it to go and usually takes a few minutes. This makes docking a ***** and could be dangerous. What the heck?
Old 06-30-2003, 04:13 PM
Charter Member #30
Scott's Avatar
My Boats: PQ 38 Avenger
You will probably find that the part that attaches to the shift fork will have an oblonged hole. The replacement is made out of a better metal that should not do this, an easy fix. To confirm try shiffting the drive with the cable that goes right to the drive from the shiffting bracket I would guess it will shift in and out with no problem. There are other things it could be but I bet it is this I had the exact same thing happen. Sorry I don't have part numbers or the right names
I have Steps & Bubbles!
Scott is offline
Old 06-30-2003, 04:26 PM
Mad Hatter
I'm confused, is the part on the shift fork then or attached to that block?
Old 06-30-2003, 04:55 PM
Charter Member #30
Scott's Avatar
Look in the tech section
Scott is offline
Old 06-30-2003, 04:56 PM
Mad Hatter
Yup got it thanks!
woodington1
3
05-23-2006 11:44 AM
Pure Energy
4
06-22-2004 09:47 PM
LVFASTCAT
5
08-19-2003 09:05 AM
Mad Hatter
15
07-07-2003 03:30 PM
bn
4
05-29-2002 09:50 PM
