Changing All Around Light Location >
Old 07-09-2003 | 01:25 PM
Iggy's Avatar
On my Formula it plugs into a socket mounted on the windshield frame and is about three feet above my head when standing. It's a two part light. The forward facing lamp is on with the running lights while the aft facing and forward comes on as an anchor light. There's a light mounted in the transom for the aft running light.
It does cast a erie glow forward when running but other than that it's not a problem.
Iggy is offline
Old 07-09-2003 | 02:25 PM
Jeff
the one in front is an anchor light. Turn it off when running. All you need is the white transom light on the back of the boat here in FL. Hence, Scarab made in Bradenton Fl. On my open fisherman I have the white light mounted on the back of one of my outboard lift off covers.
Old 07-09-2003 | 03:14 PM
WARPARTY36's Avatar
Drive to arrive alive!!!
I have a two part light on my bow, and it does not really effect night vision. The 360 deg. rule is taken care of by a light in the middle of the transom. Which is also nice to light up the platform, just incase anyone needs to relieve themselves in the middle of the night.(Not that anyone does that in Oklahoma!)
WARPARTY36 is online now
Old 07-09-2003 | 03:34 PM
mr_velocity's Avatar
Mine is on the deck too and used to blind me. Now it's 6' tall, no longer an issue.
mr_velocity is offline
Old 07-09-2003 | 04:02 PM
BAD-HABIT's Avatar
Originally posted by ChrisK
I cant see how that would be an issue... Mine is already in the back... Scarab is actually one of the only boats that I have seen with it in the front like that.
My 86 Formula has the lights on the windshield also. For your running lights the front light on the windshield pole is on and the light on the transom is also on. For anchoring the only light on is the windshield pole but then both lights on the windshield pole (front and rear) are on...I have been wanting to fix this also.....
BH
BAD-HABIT is offline
Old 07-09-2003 | 04:11 PM
eyezlee's Avatar
Ok so where can I get a 6' two part light pole and base?
eyezlee is offline
Old 07-09-2003 | 05:15 PM
My BAJA has the white light in front of the windshield but is only 135 degree. The stern has a light. When at anchor the front light goes to 360. The 135 still messes with your night vision. I bought a 360 light for my kids boat that is very directional, the light comes out in a pancake shape. This casts a beam around you but not on you. Check Ellett Brothers for this type of light. You do need to make sure you get the correct bend so it is parallel at plane or split the difference between on plane and at rest. I have considered using a LED type light temporarily mounted to the antenna for anchoring. The LED lights consume very little current. Whatever you do be sure you can be seen!
BadDog is offline
Old 07-10-2003 | 07:04 AM
Audiofn's Avatar
Charter Member #232
The rule changes at about 32 or so feet as to what you need to have for running lights last time I looked. I know you definatly need a 360 degree white light. That is the only way that other boats can tell what direction you are traveling in (by seeing the white light in relation to your grean or red bow light)
I did remove my light over the windshield and went with the stern light, and find it to be MUCH better.
Jon
Put your best foot forward!
Audiofn is offline
Old 07-10-2003 | 08:49 AM
Got to West Marine and buy a piece of alum tubing. Then drill the rivits out of the old light and base and install them into the new tubing. Took about 15 minutes to complete.
Michael Garibay
Scarab
6
06-17-2008 05:58 PM
358player
Sonic
2
09-13-2004 07:37 PM
MnFastBoat
02-18-2003 02:56 PM
MnFastBoat
02-17-2003 08:42 PM
MnFastBoat
02-17-2003 07:02 PM
