Opinions on boost
Old 07-10-2003 | 09:08 AM
birdog's Avatar
Default Opinions on boost
I am running 468s with good internals..No Intercoolers
4 lbs boost from Blower shop 871s.......
People are telling me i can go 5-5.5 lbs no problem....4 lbs is just overcoming the drag from blowers.
I don't do any of those long WFO runs...just short burst when needed
Whadaya think ?
birdog is offline
Old 07-10-2003 | 10:35 AM
sgrady's Avatar
Compression ratio ? Heads ? You need more details in order to make those calls.
sgrady is offline
Old 07-10-2003 | 11:39 AM
Dano's Avatar
Birdog,
Cat's right...put those coolers on there big boy!!! I keep mine at 5lbs, your motors could do 5 or 5.5 pretty easy.
Dano is offline
Old 07-10-2003 | 12:32 PM
bobby daniels
Not to argue but I've run little 250 b&m blowers for years on 468's and 482's with 6 pounds and no innercooler and 8.75 to 9 to 1 comp. so the 8-71 is even bigger hence much less heat than even a B&M mega blower -420/6-71--. sooo the 6 lbs on bird dog should be fine unless theres something big he's not disclosing
It does take about 2.75 to 3 on the dyno to make up for the 8-71 parasitic loss
Bird dog your wasting money with that blower unless you spin it harder and a innercooler is not needed in your case with the facts I know .
just put in some new plugs make a pass short hard one read plugs and adjust from there and run about 32* total timing syn.oil ,,MSD,, and smile
Old 07-10-2003 | 04:15 PM
birdog's Avatar
I did leave out a very important fact........8:1 Comp........Doh !!
New GM Big Oval port heads.......
I like Bobbys answer the best !!!!!!!!!!!1
birdog is offline
Old 07-10-2003 | 04:23 PM
birdog's Avatar
Dano.......Intercoolers are not in the budget right now........
unless you have a pair ??????? want to help a po boy out ??
birdog is offline
Old 07-10-2003 | 05:51 PM
Turbojack's Avatar
Intercoolers & 9 lbs of boost
Turbojack is offline
KNOT-RIGHT
62
06-05-2022 08:03 AM
tomlesli
04-13-2007 02:02 PM
Fountaineer
8
06-25-2004 06:49 PM
Roger Perkins
16
05-03-2004 05:15 PM
Cord
04-20-2003 08:12 PM
