Ringo is some BAD AZZ Chit!!! >
Old 04-27-2004 | 07:09 AM
OldSchool's Avatar
Originally posted by Reckless32
Man that must be some crappy water up in the Potomac.....OR on/off has been used on that hull making it yellow really quick... Looks like you better stock up Craig...
I think that it was something in the water (fungus or something). Didn't happen last fall! I ordered some Frenzy to wax the bottom with, just waitin' on it to get here!
And, for the record, It was doo-doo brown for the color, not yellow!!
OldSchool is offline
Old 04-27-2004 | 08:24 AM
Strip Poker 388's Avatar
Rob
Must of been in the Red Sea
I wonder if it etching the bottom gel coat making it stain easier??
Strip Poker 388 is offline
Old 04-27-2004 | 09:14 AM
Downtown42's Avatar
geez, a couple days and you got to deal with that?
Downtown42 is offline
Old 04-27-2004 | 09:55 AM
OldSchool's Avatar
Like I said , It's never happened before.
Old 04-27-2004 | 10:02 AM
BillR's Avatar
OSO Moderator
Ringo does not harm gel. On/Off does.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 04-27-2004 | 10:47 AM
Miami
aware that On/off, the acis is harmfull to gelcoat. What proof do you or Viper340 have that Ringo does not. Please do not take this the wrong way. I want to use Ringo. what facts or evidence do you have regarding it's safety on wax and / or gelcoat. Please convince me
thanks
Old 04-27-2004 | 10:58 AM
Chris288's Avatar
Since when is on-off harmful to gel coat or fiberglass ??
Marykate's On & Off hull and bottom cleaner
The hottest selling hull cleaner on the marine market today!
Instantly removes waterline stains, algae stains, rust and gas exhaust stains. Softens barnacles for easy removal. Not harmful to fiberglass. Simply brush on and rinse away. Biodegradable.
A little information about this cleaner and what it will remove:
If it is a stain, MaryKate's On & Off Hull & Bottom cleaner, which basically contains a combination of three different acids - including oxalic acid which will remove tree sap, gas, rust, diesal soot etc. It is very powerful stuff, and you DO NOT want to get on any metal or fabric, it is however, safe for fiberglass non-skid gelcoats decks .You should also try not to get it on your trailer, concrete, blacktop etc.
This will usually do the trick, if it is being really stubborn, very, very lightly agitate with a fine bronze wool pad and use the ON & OFF (but this is only used as the last resort). Be sure to rinse away fibers from wool pad after your done.
You will then need to reapply a wax or polish on the area that you cleaned with the On & Off cleaner, as with any hull or abrasive cleaner.
Chris288 is offline
Old 04-27-2004 | 12:14 PM
Macklin's Avatar
I can speak from experience here. I think we all know how caustic On/Off is. Ringo is nothing like that. I have been using it for two solid summers with great success and absolutely no apparent wear on the gelcoat. As a matter of fact, I do not wax my bottom anymore like I used to. When it starts to yellow just a bit I give it a quick application of Ringo and it looks freshly waxed again. And I have not noticed any increase in the yellowing in the past two summers. Actually Ringo keeps the bottom clean and shiny longer than wax.
I am about due for my first application of the year. If I can remember, I will snap some before and after pics for y'all.
Macklin is offline
Old 04-27-2004 | 12:17 PM
bcoffield's Avatar
Registered User
Who sells it?
bcoffield is offline
Old 04-27-2004 | 09:22 PM
Steve_H
Originally posted by bcoffield
Who sells it?
oso member Viper340
