need new oil coolers
Old 07-14-2004 | 08:58 AM
phughes69's Avatar
Default need new oil coolers
I am finnally getting closser to putting my boat in the water, when yesterday I went to fire the motors and I was getting oil out of the port exhaust. I bypassed the oil cooler and the oil stopped. I was having the same problem on the starboard motor, but much worse. I guess the guy I bought the boat from did not put any antifreeze in the cooling lines, and did not blow out them either, (but he did drain the blocks and manifolds). I need to find new oil coolers asap. The old cooler measures 19" long end to end and 2" in dia, they sat on the outboard side of the motors and there are 2 per engine. The engines are 468 with twin turbos that make about 550 hp. Who had decent priced coolers (since I may have to buy 4).
phughes69 is offline
Old 07-14-2004 | 09:39 AM
velocity280's Avatar
Default Re: need new oil coolers
Todd at Revolution Marine was very helpful to me...they have a 3" x 18" for $199.00. It dropped my oil temps by 60 or mor degrees. I believe their site is www.revolutionmarine.com
velocity280 is offline
Old 07-14-2004 | 09:54 AM
PatriYacht's Avatar
A single 3" cooler has more surface area than 2 2" coolers and would allow you to simplify your plumbing. Less restriction = more oil and water flow and better cooling. I got mine at Eddie Marine 200.00 ea.
PatriYacht is offline
Old 07-14-2004 | 10:12 AM
Waterfoul's Avatar
Gone Fishin'
I am also running an Eddie 3" cooler. When my motor ran [sic] I could run pretty much all day without my oil ever getting above 220-225 or so. Slick unit.
Waterfoul is offline
Old 07-14-2004 | 10:15 AM
I have a new Mercury racing cooloer from their 800hp motors and I works great. I cant get the oil above 190.
ActiveFun is offline
Old 07-14-2004 | 11:03 AM
phughes69's Avatar
I found this, what do you guys think about it
Part No.: 620-2212-WE-03 Category: Engine Oiling Systems-Oil Coolers
Hardin Marine Dual Tandem Oil Cooler
Description: Tandem Cooler 3/4 NPT Oil Connections, 1-1/4" Push-on Water Connection. This is one of the best designs anywhere. Two coolers and only one water hose connection. Each tube consists of thirty-one 1/4" seamless tubes with displacement baffles so you can be assured you're getting maximum cooling when you need it.
List Price: $299.95
Your Price: $225.00
You Save: $74.95
Old 07-14-2004 | 11:19 AM
Waterfoul's Avatar
Gone Fishin'
how big is it? Will it fit where you need it to go? If so, it might be just the ticket for you.
Old 07-14-2004 | 01:24 PM
Poorsche's Avatar
I've got a pair of these I bought and am not going to use---brand new/never installed.
PM or email for price and location
Poorsche
www.boatmat.com
Poorsche is offline
Old 07-14-2004 | 01:25 PM
phughes69's Avatar
It will fit where the old one was. I have plenty of room on the outboard side of the motors. It is 18" long and each cooler is 2" dia
dean51267
14
08-05-2006 12:07 AM
johnnyboatman
15
02-23-2006 01:21 AM
Shah Mat
13
11-30-2003 08:46 PM
BRUCE SEROFF
6
03-27-2003 04:39 PM
